[GeoNetwork-devel] Temporal searches
Hi
Anyone know why the temporal search in the LuceneQueryBuilder works like this:
  • temporal extent start is within search extent
  • or temporal extent end is within search extent
  • or temporal extent contains search extent
The third condition, if you search from an “invalid” range: (from: 2014-10-07, to: 2013-01-01) causes to return results as produces a lucene query term like: tempExtentEnd:[2013-01-01 TO ], tempExtentBegin:[ TO 2014-10-10]
Sorry, but I don’t get the reason of this condition, except maybe to be more permissive in the searches? But anyway, produces bizarre results.
See the code in https://github.com/geonetwork/core-geonetwork/blob/develop/core/src/main/java/org/fao/geonet/kernel/search/LuceneQueryBuilder.java#L598
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jose,
I think the temporal search works in a more permissive ‘overlapping’ mode i.e you will get anything inside the temporal range
you specify or anything that overlaps.
I you needed more exact control over the search range
you can use CSW search e.g this worked to give me all records within or equal to a range:
= AND <= (inclusive range)
<ogc:Filter xmlns:gml=“http://www.opengis.net/gml” xmlns:ogc=“http://www.opengis.net/ogc”>
ogc:And
ogc:PropertyIsGreaterThanOrEqualTo
ogc:PropertyNameTempExtent_begin</ogc:PropertyName>
ogc:Literal1990-01-01T22:21:56.000Z</ogc:Literal>
</ogc:PropertyIsGreaterThanOrEqualTo>
ogc:PropertyIsLessThanOrEqualTo
ogc:PropertyNameTempExtent_end</ogc:PropertyName>
ogc:Literal2009-12-31Z</ogc:Literal>
</ogc:PropertyIsLessThanOrEqualTo>
</ogc:And>
</ogc:Filter>
HTH
Andrew
From: Jose Garcia [mailto:jose.garcia@anonymised.com]
Sent: Friday, 10 October 2014 8:35 PM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Temporal searches
Hi
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Andrew
I can’t use CSW for this, but thanks for confirming my suspects about the reason for this.
Jose García
On Tue, Oct 14, 2014 at 1:43 AM, Andrew Walsh <awalsh@anonymised.com> wrote:
Hi Jose,
ogc:And
</ogc:And>
</ogc:Filter>
HTH
Andrew
Hi
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
