The codeList url (in my template) is changed when creating a new metadata record:
http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#CI_OnLineFunctionCode
http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_OnLineFunctionCode
Note the change in casing from ‘codelist’ to ‘Codelist’.
GN work with the new url casing, but it cause the GDI-DE validator to fail the record. (The standards.iso.org server is case sensitive)
Is there a way to stop this from happening?
Thanks!
