Hi:
I want to use the csw client in the geonetwork,but I found that the sources need some other library (org.dlib.gui…),I wonder where can find this library?
This dlib library appears to be from the Druid project
See here under the "DruidLib" section:
http://sourceforge.net/projects/druid/files/
The version used in GeoNetwork should be 1.5.
Although the file type in the .tgz file is not specified, it is a .tar file
and should have the dlib.jar in it.
View this message in context: http://n2.nabble.com/the-dlib-tp3910605p4587018.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
