[GeoNetwork-devel] The Map-Viewer don't allow singleTile setting
using GN 2.7.0-trunk
I try to set the mapViewer to do calls with
singleTile: true
option set as allowed from OpenLayers,
but it seem don’t work.
When I add this setting the Interface don’t startup correctly and stay freeze to the start.
The same setting work withount problem on a simple OpenLayers (v 2.11) page.
But before open a ticket, I like to have some confirm because I’m not sure this setting can put on the “option” variable in the geonetwork mapviewer settings.
So I don’t know if this is a bug or an enhancement.
Andrea Peri
qwerty àèìòù
