[GeoNetwork-devel] The Map-Viewer don't allow singleTile setting
I resend my question.
I guess is this pretty relevant.
Because many WMS servers will use a watermark, and
without the singleTile option the Viewer become a grid of watermarks..
I try many combination, but the OpenLayer singleTile option don't work.
I like to know if this is a know limit.
Andrea.
>Hi,
>using GN 2.7.0-trunk
>I try to set the mapViewer to do calls with
>singleTile: true
>option set as allowed from OpenLayers,
>but it seem don't work.
>When I add this setting the Interface don't startup correctly and stay
>freeze to the start.
>The same setting work withount problem on a simple OpenLayers (v 2.11) page.
>But before open a ticket, I like to have some confirm because I'm not sure
>this setting can put on the "option" variable in the geonetwork mapviewer
>settings.
>So I don't know if this is a bug or an enhancement.
Andrea Peri
qwerty àèìòù
