Hi
In the angular metadata editor I see that when switching to the Full view is displayed a thesaurus selector, but unfortunately it is not available in the Simple view.
I see the related code seem to be in ThesaurusDirective.js and the thesaurusselector.html, but can’t figure out where is managed the display of this thesaurus selector to allow display them in the Simple view.
Is this something that can be configured in a file or requires some development changes? Any idea where to start checking to enable it in the Simple view? Also any reason to don’t display the selector now in the Simple view, looks a quite useful feature.
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Related to this:
BTW if your template already set a keyword section from an existing thesaurus, you’ll get the keyword selection in the simple view
Sure if I add a keyword from a thesaurus in full view and get back to simple view, I got the keyword control to limit the values to that thesaurus, but I would like to know if it’s possible also to enable the button to add a new keyword from thesaurus in the simple view (at least in classic with the binoculars icon was possible this from the simple view)
Jose García
On Wed, Apr 23, 2014 at 3:28 PM, Francois Prunayre <fx.prunayre@anonymised.com.> wrote:
Hi
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2014-04-23 12:22 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
This is due to the “flat” mode used for the simple view ie. does not display what does not exist in the record.
BTW if your template already set a keyword section from an existing thesaurus, you’ll get the keyword selection in the simple view.
Changes may be required at least in the XSL and eventually in config-editor.xml.
Francois
Thanks and regards,
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
GeoNetwork-devel mailing list
