[GeoNetwork-devel] Ticket #501 Incorporation?
http://trac.osgeo.org/geonetwork/ticket/501
Wondering if the patch submitted by my colleague ever found its way into the code base? I don’t see any evidence of it having been addressed. We put in this functionality for a production system that needs to be updated and are hoping it is in so we don’t have to go through the effort of adding the functionality again.
Thanks!
Hi David
I’m going to assign the issue to me and will check to integrate. Not going to be this week, but from next week will manage about this.
Do you have any server available with this type of layers to test?
Jose García
On Wed, Mar 6, 2013 at 12:16 AM, Blodgett, David <dblodgett@anonymised.com> wrote:
Thanks!
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Here is a layer definition line from config-gui.xml:
It is implemented on this instance of geonetwork: http://cida.usgs.gov/glri/geonetwork/srv/en/main.home
  • Dave
On Wed, Mar 6, 2013 at 12:54 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi David
Jose García
Thanks!
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
