[GeoNetwork-devel] Tomcat 5.5 hangs when hosting GN 2.2.0 [SEC=UNCLASSIFIED]
All,
GeoNetwork 2.2.0 is deployed into Tomcat 5.5.26. When attempting to shutdown the application hangs. Tomcat does not cleanly exit. This is causing problems in unix as the process must be manually killed (ports are being held open).
The problem appears to be with the way org.wfp.vam.intermap.kernel.TempFiles uses the Timer API. Changing line 55 from:
timer = new Timer();
to:
timer = new Timer(true);
forces the Timer to use a daemon thread. This allows Tomcat to shutdown completely.
Stephen Davies
Stephen.Davies@anonymised.com wrote:
All,
to:
1. At startup, Jetty prepares for its future shutdown
    by using Runtime.addShutdownHook.
    When the time for shutdown comes, it calls System.exit(0),
    and the previously-registered shutdown hook does the
    work of stopping the applications. A stray timer (or
    other thread) can not stop shutdown.
2. Tomcat does not use System.exit(0) to shut down.
    This is a deliberate design decision.
    Applications are expected to clean up all threads.
A side-effect of doing GN development using
Jetty is that the "problem" of cleaning up threads
is swept under the carpet. Checking the
behaviour under Tomcat keeps us honest . . . .
In this case, the problem is that the Intermap
class starts up two Timer threads,
but only shuts down one of them.
1. The start() method does:
      GlobalTempFiles.init(path, tempDir, delete);
      tempFiles = GlobalTempFiles.getInstance();
    and the stop() method does:
      tempFiles.end();
    So far, so good.
2. The start() method also does:
      MapMerger.setCache(new HttpGetFileCache(path, cacheDir,
        deleteCache));
    The constructor of HttpGetFileCache starts
    a Timer. But nowhere is there a call to stop
    it.
Steve's change to the TempFiles class certainly
fixes the problem.
Here's another way to do it that matches the
cleanup of tempFiles.
1. Add the following method to HttpGetFileCache.java:
     public void end() {
         tf.end();
2. In Intermap.java:
(a) Add the following field to the class:
     private static HttpGetFileCache httpGetFileCache;
(b) In the start() method, change:
         deleteCache));
     to:
       httpGetFileCache = new HttpGetFileCache(path, cacheDir,
         deleteCache);
       MapMerger.setCache(httpGetFileCache);
(c) Add the following line to the stop() method:
       httpGetFileCache.end();
I've done a quick test of this with Tomcat 5.5.26
and it seems to do the trick.
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
An easier workaround to this Tomcat problem than recompiling Intermap is to
use the "-force" option of the tomcat start/stop scripts. This doesn't fix
the problem, of course, but it saves the effort of manually tracking and
killing the tomcat process each time.
    $ export CATALINA_PID=~/catalina.pid
    $ startup.sh
    (use tomcat for a while...)
    $ shutdown.sh -force
(You can use: "catalina.sh stop -force" instead of "shutdown". If you define
CATALINA_PID in your login script (e.g. .bash_profile), you don't need the
"export" command.)
--Rich
Richard Fozzard, Computer Scientist
  Geospatial Metadata at NGDC: http://www.ngdc.noaa.gov/metadata
Cooperative Institute for Research in Environmental Sciences (CIRES)
Univ. of Colorado and NOAA National Geophysical Data Center, Enterprise Data
Systems
325 S. Broadway, Skaggs 1B-305, Boulder, CO 80305
Office: 303-497-6487, Cell: 303-579-5615, Email: richard.fozzard@anonymised.com
Stephen.Davies-2 wrote:
All,
shutdown
problems
open).
View this message in context: http://www.nabble.com/Tomcat-5.5-hangs-when-hosting-GN-2.2.0--SEC%3DUNCLASSIFIED--tp17660763p19078219.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
