[GeoNetwork-devel] Transferring ownership of Metadata
Hi List,
Having recently started adding some metadata to our instance of GeoNetwork, I would now like to transfer the ownership of these records to another user. However, when I try this from the Administrator page, an alert dialogue pops up informing me:
  "There are no editors with associated metadata".
What does this mean? I've been using a build from SVN to make use of the recently-added ISO 19119 support. Would this make a difference?
Any ideas would be very welcome.
Many thanks,
Andy
I'll have a go at answering this one and maybe the author can correct me if I'm wrong:
If you are logged in as an administrator then you'll get a list of metadata record owners that are editors - if there aren't any then you'll get the message "There are no editors....".
If you are logged in as a useradmin then you'll get a list of metadata record owners that are editors and share the same set of groups as you - if there aren't any then you'll get the message "There are no editors....".
A catch here is to make sure that all registered users have a surname and name field - otherwise the select lists shown by transfer ownership will be blank.
Work is needed on some additional owner based functions to add to 'Transfer Ownership'.
Simon
________________________________________
From: geonetwork-devel-bounces@lists.sourceforge.net [geonetwork-devel-bounces@lists.sourceforge.net] On Behalf Of Andrew Chamberlain [andyc@anonymised.com]
Sent: Wednesday, 17 September 2008 12:29 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Transferring ownership of Metadata
Hi List,
Many thanks,
Andy
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-devel mailing list
