Dear all,
With the release of the first Release Candidate for GeoNetwork v2.4.0 it is also time to update your translations Attached is the output of an automated check that compared all language strings in the English version with the other languages currently available in trunk.
If you can, please provide your input to us so the updates can be integrated before the final release.
These checks only apply to the strings in the main "loc" folder of the geonetwork application. If you also want checks to be done on other parts of the system, you may do those yourself following the instructions on synch_lang – GeoNetwork opensource Developer website
Thanks in advance for your efforts,
ciao,
Jeroen
(attachments)
localization_errors.txt (49 KB)
