Using Maven 3.0.2, ANT 1.8.2 and Java JDK 1.6.0_25 on a Debian 32 bit,
I was able to build GN from trunk until some week ago.
But now Maven report me some Errors.
This is the error it report for
trying to build the last trunk version (r7840) :
[INFO] Building GeoNetwork opensource 2.7.0-SNAPSHOT
Downloading: http://oss.sonatype.org/content/repositories/github-releases/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
597 B [WARNING] Checksum validation failed, could not read expected checksum: Error transferring file: Connection timed out for http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
[WARNING] Could not transfer metadata org.apache.maven.plugins:maven-compiler-plugin/maven-metadata.xml from/to central (http://repo1.maven.org/maven2): Error transferring file: Connection timed out
[INFO] Reactor Summary:
[INFO]
[INFO] GeoNetwork opensource … FAILURE [6:19.662s]
[INFO] Caching xslt module … SKIPPED
[INFO] Jeeves modules … SKIPPED
[INFO] Oaipmh modules … SKIPPED
[INFO] ArcSDE module (dummy-api) … SKIPPED
[INFO] GeoNetwork Web module … SKIPPED
[INFO] GeoServer module … SKIPPED
[INFO] Gast module … SKIPPED
[INFO] GeoNetwork Integration Tests … SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:22.349s
[INFO] Finished at: Fri Jun 10 12:17:22 CEST 2011
[INFO] Final Memory: 3M/39M
[ERROR] Error resolving version for plugin ‘org.apache.maven.plugins:maven-compiler-plugin’ from the repositories [local (/home/archivio/tomcat/.m2/repository), oss.sonatype.org-github-releases (http://oss.sonatype.org/content/repositories/github-releases), central (http://repo1.maven.org/maven2))]: Plugin not found in any plugin repository → [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginVersionResolutionException
Also I attach the full Log to this email.
I try some changing to the pom.xml but without success.
I like to know if this is a generalized problem or if is only for my PC.
thx,
Andrea Peri
qwerty àèìòù
(attachments)
log.txt (12.2 KB)
