Hello everybody,
I'm trying to install Geonetwork 1.2.1 on Tomcat 4.1.31 on Windows Server 2003. The Tomcat server is running correctly but log me the following error on starting:
WebappClassLoader: validateJarFile(C:\Program Files\geonetwork\web\WEB-INF\lib\jsdk2.3.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
Then when I try to access the geonetwork main page, I got the following :
javax.servlet.ServletException: L''exécution de la servlet a lancé une exception
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:222)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:146)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:209)
at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:596)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:433)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:948)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:144)
at org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2358)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:133)
at org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:118)
at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:594)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:116)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:127)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:152)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:705)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:595)
cause mère
javax.xml.transform.TransformerFactoryConfigurationError: Provider org.apache.xalan.processor.TransformerFactoryImpl not found
at javax.xml.transform.TransformerFactory.newInstance(Unknown Source)
at jeeves.utils.Xml.transform(Xml.java:90)
at jeeves.utils.Xml.transform(Xml.java:72)
at jeeves.server.dispatchers.output.OutputDispatcher.dispatchGui(OutputDispatcher.java:270)
at jeeves.server.dispatchers.output.GuiTag.invokeNamedService(OutputPage.java:330)
at jeeves.server.dispatchers.output.GuiTag.invoke(OutputPage.java:281)
at jeeves.server.dispatchers.output.OutputPage.invokeGuiServices(OutputPage.java:159)
at jeeves.server.dispatchers.output.OutputDispatcher.dispatch(OutputDispatcher.java:157)
at jeeves.server.dispatchers.main.MainDispatcher.dispatch(MainDispatcher.java:131)
at jeeves.server.Jeeves.doPost(Jeeves.java:557)
at jeeves.server.Jeeves.doGet(Jeeves.java:499)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:696)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:809)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:200)
I think the jsdk23.jar file from the geonetwork directory and the common Servlet.jar file of tomcat implement the same thinks so tomcat do not load the jsdk23.jar and then can not find some functions...
Does someone have some idea on how to fix this problem.
Thanks by advance.
Andéol AYZAC
Grand Lyon - Lyon Urban Community
