[GeoNetwork-devel] Trunk error
Hello,
When I run the application from trunk I see the following error. Any clue why this happens?
012-05-28 15:28:29,828 ERROR [jeeves.engine] - Handler : org.fao.geonet.Geonetwork
2012-05-28 15:28:29,828 ERROR [jeeves.engine] - Exception : org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
2012-05-28 15:28:29,828 ERROR [jeeves.engine] - Message : ERROR: current transaction is aborted, commands ignored until end of transaction block
2012-05-28 15:28:29,828 ERROR [jeeves.engine] - Stack : org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:367)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:271)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at jeeves.resources.dbms.Dbms.selectFull(Dbms.java:213)
at jeeves.resources.dbms.Dbms.select(Dbms.java:176)
at org.fao.geonet.kernel.AccessManager.(AccessManager.java:81)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:325)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:541)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:170)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:85)
at javax.servlet.GenericServlet.init(GenericServlet.java:212)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1173)
Regards
Kumaran
