[GeoNetwork-devel] Updated trac to support 2.8.0 tickets
Francois,
When you get a chance can you update trac so that you can specify version
2.8.0 when reporting a bug. And also add milestone 2.8.1.
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Updated-trac-to-support-2-8-0-tickets-tp5037094.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Is there someone else that has permissions to make these changes? Looks like
Francois is busy
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/Updated-trac-to-support-2-8-0-tickets-tp5037094p5038860.html
Hi Ian,
2013/3/6 ianwallen <ianwallen@anonymised.com>
Francois is busy
Yep. I’m back online.
Version and milestone added to trac. For other trac admins, you can add them in:
http://trac.osgeo.org/geonetwork/admin/ticket/versions
http://trac.osgeo.org/geonetwork/admin/ticket/milestones
Maybe we should add a step in the release guideline:
Add the version (eg. v2.8.0) to the trac with its release date in:
Add the next minor version (eg. 2.8.1) in:
Cheers.
Francois
Thanks
Francois,
Thanks - can you also close the 2.8.0 milestone as we should not be
targeting any fixes to that milestone.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Updated-trac-to-support-2-8-0-tickets-tp5037094p5039333.html
