[GeoNetwork-devel] upgrade database from 1 month-old trunk to current trunk
I’ve got a running geonetwork from the trunk code, 1 month ago. Since then, there have been quite a few changes, some in the database.
I understand we’ve got the migrate sql codes, that would allow, I believe, to upgrade a database from gn 2.6.4 to trunk (2.7.0)
But trying to apply it on my postgresql database, I get many errors, since most of the structure and data is yet here, but not all…
Do you know an “easy” way to do such an upgrade ?
Note : the DB is yet configured, with many metadatas inside, so I would prefer not the make it from scratch and reimport the data. If possible…
Jean
By the way, it looks like there are some errors in the migration sql script : turkish (tur) language is missing, and the new ones seem not to be inserted in the tables (vie, nor, fin)
2012/4/2 Jean Pommier (IGE) <jean.pommier@anonymised.com>
Jean
OK, I’ve tried, changing a little bit the migration script’s code in order to get it working smoothly.
But even then, when I launch geonetwork against this “up to date” database, I get errors for each of my metadatas :
ERROR [geonetwork.datamanager] - The metadata document index with id=134 is corrupt/invalid - ignoring it. Error: ERROR: current transaction is aborted, commands ignored until end of transaction block
org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:367)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:271)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at jeeves.resources.dbms.Dbms.selectFull(Dbms.java:210)
at jeeves.resources.dbms.Dbms.select(Dbms.java:181)
at org.fao.geonet.kernel.XmlSerializer.internalSelect(XmlSerializer.java:92)
at org.fao.geonet.kernel.XmlSerializerSvn.internalSelect(XmlSerializerSvn.java:72)
at org.fao.geonet.kernel.XmlSerializerSvn.selectNoXLinkResolver(XmlSerializerSvn.java:107)
at org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:436)
at org.fao.geonet.kernel.DataManager.indexMetadataGroup(DataManager.java:419)
at org.fao.geonet.kernel.DataManager$IndexMetadataTask.run(DataManager.java:367)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
and the result is almost nothing works (no metadata loaded, not possible to login)
Checking with an old gn 2.6.4 database, I can confirm there seem to be errors in the 2 char lang codes (‘es’ in place of ‘sp’, ‘pt’ in place of ‘po’, turkish absent, etc) in the migration script.
I’m definitely going to fill a ticket.
Jean
