Hello everybody
I am working to upgrade GN 2.1 to 2.2. I installed GN 2.2 without problems,
I am doing now manually the database (MySQL) because I tried to use GAST and
I could not update it with this tool. I already have the updated database
but when I use "web-inf\config.xml" to connect to GN I don't get results
from DB. So I would like to know what more I have to do to fix this problem.
I hope somebody can help me.
Claudia Perea
:working:
View this message in context: http://www.nabble.com/Upgrade-Geonetwork-2.1-Alpha-to-2.2-tp18350355p18350355.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
I found a good solution here
http://www.nabble.com/Update-GN-2.0-to-2.2-td16953728.html#a16955570
ClaudiaJ wrote:
Hello everybody
problems, I am doing now manually the database (MySQL) because I tried to
use GAST and I could not update it with this tool. I already have the
updated database but when I use "web-inf\config.xml" to connect to GN I
don't get results from DB. So I would like to know what more I have to do
to fix this problem. I hope somebody can help me.
Claudia Perea
:working:
View this message in context: http://www.nabble.com/Upgrade-Geonetwork-2.1-Alpha-to-2.2-tp18350355p18371026.html
