On 2.10.x we upgraded from Jetty 7.3.1 to Jetty 7.6.8 in order to fix a JSP
compilation issue. I had suggested that we should be going even further in
the develop branch by upgrading to a more recent version of Jetty. So I have
made a quick attempt to upgrade to 8.1.12 and I have it mostly working
however I have hit a bug with the current version of ICU4J
http://icu-project.org/trac/ticket/6505
The fix involves upgrading ICU4J from 2.6 to 2.8 on geonetwork and
geoserver. Could someone point me to where and how to proceed with this
upgrade -I can't seem to find it. Also I don't know much regarding ICU4J so
does anyone know if it will cause any issues if we perform this upgrade? I
did manage to replace all occurrences of icu4j-2.6.1.jar by icu4j_2_8.jar in
the lib folders and it solved the issue with Jetty 8 - I'm just not sure if
it introduced any new bugs?
Note: I originally attempted to upgrade to Jetty 9 however it required Java
1.7. I did think it was worth forcing the requirement of Java 1.7 based on
Jetty. When future changes change the requirements to Java 1.7 then we can
look at upgrading Jetty to version 9 and beyond.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upgrading-jetty-to-version-8-on-develop-tp5072040.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Ian,
2013/8/12 ianwallen <ianwallen@anonymised.com>:
ICU4J is a dependency of Jaxen.
Upgrading jaxen to 1.1.4 in pom.xml fixed the issue. See
https://github.com/geonetwork/core-geonetwork/issues/223
So far, I did not noticed any issue.
Cheers.
Francois
I
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It's a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Francois,
Thank you for that information. - I knew it was an easy fix - just could not
find it.
I noticed that you called the issue "Upgrade Jetty to 8.x or 9x version".
Are you planning on going with 9 (and make geonetwork dependent on Java 1.7)
or are you going with version 8? Just curious - thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upgrading-jetty-to-version-8-on-develop-tp5072040p5072049.html
Francois,
find it.
8 is fine for me and I only find jetty maven plugin for 8 version.
Francois
