[Geonetwork-devel] Using other interactiveweb map client software (search via map?)
This may be similar to the search via map thread. I would like to have the
capability to set the bounding coordinates using a map interface and also
present the information gathered from WMS. I would like to use a web map
client called Internet Mapping Framework (IMF).
Is GeoNetwork loosely coupled enough to allow IMF (or any other WMC) to be
the map component of the interface? If so what is the API and where is the
documentation to integrate the WMC with the other components?
Thanks.
John
