Hello List,
When harvesting from ArcSDE you will find that ESRI encapsulates their UUID with {}.
Next if you search for this UUID with {}, the CSW server chokes.
In the filter to lucene transformation there is an Xpath substitution in the txt attribute.
I am not quite sure what goes wrong. It needs further investigation.
For now you cannot find metadata based on UUID if generated bij ArcGis.
I will let you know if I get a grip on it, but maybe someone else has solved this.
Regards
Chris
