Local filesystem harvesting does not report sucess in tool-tip as other harvesters (eg csw) do. Fix is:
- ensure “result” variable has class rathre than local scope:
diff fixed\LocalFilesystemHarvester.java old\LocalFilesystemHarvester.java
184c184
< result = new LocalFilesystemResult();
LocalFilesystemResult result = new LocalFilesystemResult();
- Copy:
geonetwork/web/geonetwork/xsl/harvesting/csw/client-result-tip.xsl
to
geonetwork/web/geonetwork/xsl/filesystem/csw/client-result-tip.xsl
Guess someone needs to feed this into the tree as I’m not a committer.
Regards
Peter
