I am using Geonetwork 2.8.
Currently I am harvesting XML files in Web Access Folder. Technically it works very well. The problem is that all XML files are harvested.
I would like to filter using keywords, e.g. one harvesting with keyword 1 and another harvesting with keyword 2.
I must have missed something, but I did not see any option in the Geonetwork harvesting management window.
Is it possible?
Thanks for your reply.
With best regards - Avec mes meilleures salutations,
Pierre Lacroix, PhD.
Scientific Collaborator - University of Geneva - Pole in Environmental Sciences
GIS Analyst - United Nations Environment Programme - UNEP/DEWA/GRID-Geneva
http://www.unige.ch/envirospace
I am posting again this question about harvesting in “Web access folder”
mode using keywords.
I can harvest in “Web access folder” mode but I need to filter using
keywords.
Is it possible and how?
P.
De : Pierre Marcel Anselme Lacroix
Envoyé : mardi 22 avril 2014 17:20
À : geonetwork-devel@lists.sourceforge.net
Objet : Web Access Folder harvesting using keywords
Is it possible?
Hi Pierre
I’m afraid this is not available now. Can be developed, but the filter should be applied in the harvester code once the metadata has been retrieved from the server as can’t send queries to the server to get the metadata already filtered.
Jose García
On Fri, Apr 25, 2014 at 3:26 PM, Pierre Marcel Anselme Lacroix <Pierre.Lacroix@anonymised.com6…> wrote:
keywords.
P.
Is it possible?
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Thanks a lot for your reply.
On Fri, Apr 25, 2014 at 3:26 PM, Pierre Marcel Anselme Lacroix <Pierre.Lacroix@anonymised.com> wrote:
keywords.
P.
Is it possible?
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
