[GeoNetwork-devel] What does the {/root/gui/searchDefaults/remote} in the main-page.xsl file? [SEC=UNCLASSIFIED]
Hi All,
I'm trying to work out to switch on "remote search" in GN 2.2 (or BlueNet MEST 2.2). I have found an HTML input variable called "remote" in the geonetwork/xsl/main-page.xsl file. I believe should be set to "on" however, the value is "{/root/gui/searchDefaults/remote}". I suspect that this is a variable of some type - I have never written AJAX - but I don't know where is it set.
In what file, where and how to I set this variable(?) to "on"?
Thanks.
John Hockaday
Geoscience Australia
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
http://www.ga.gov.au/
john.hockaday\@ga.gov.au
Hi John,
If you want to turn on the geonetwork Z39.50 server so that other sites
can search your site remotely, you can turn it on in Administration /
System Configuration settings.
When you turn this on, you specify a port. This port on your server must
be accessible by the remote sites (i.e. not firewalled).
Craig Jones
eMII Infrastructure Programmer
IMOS e-Marine Information Infrastructure Facility (eMII)
Ph: +61 3 6226 8567
On Thu, 2009-06-04 at 13:47 +1000, John.Hockaday@anonymised.com wrote:
Hi All,
Thanks.
John Hockaday
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
OpenSolaris 2009.06 is a cutting edge operating system for enterprises
looking to deploy the next generation of Solaris that includes the latest
innovations from Sun and the OpenSource community. Download a copy and
enjoy capabilities such as Networking, Storage and Virtualization.
Go to: http://p.sf.net/sfu/opensolaris-get
GeoNetwork-devel mailing list
Hi Craig,
Thanks for that information but I have already turned on the Z3950 search of my GN instance. What I want to do is change the web page so that I can search other remote repositories using Z3950. I have edited the repositories.xml.tem file but I haven't been able to get the list of repositories shown in the main web page.
Thanks.
John
-----Original Message-----
Sent: Thursday, 4 June 2009 1:59 PM
To: Hockaday John
Cc: geonetwork-devel@lists.sourceforge.net;
anzlicmet-l@anonymised.com
Subject: Re: [GeoNetwork-devel] What does the
[SEC=UNCLASSIFIED]
Hi John,
other sites
server must
Craig Jones
Ph: +61 3 6226 8567
> Hi All,
> Thanks.
> John Hockaday
> GPO Box 378
> Canberra ACT 2601
> (02) 6249 9735
enterprises
includes the latest
a copy and
Hi John,
I thought remote searching was on by default. I have a default install
and am able to change repository entries with no problems.
Note that if you have a syntax error in your repositories.xml.tem then I
don't think your changes will be picked up.
Check jetty/log/geonetwork.log or whereever you put log files to see if
geonetwork encountered any errors accessing repository.xml or
repository.xml.tem.
CraigJ
On Thu, 2009-06-04 at 14:07 +1000, John.Hockaday@anonymised.com wrote:
Hi Craig,
Thanks.
John
> From: Craig Jones [mailto:jonescc@anonymised.com]
> To: Hockaday John
> [SEC=UNCLASSIFIED]
> Hi John,
> other sites
> server must
> Cheers,
> Craig Jones
> Ph: +61 3 6226 8567
> > Hi All,
> > Thanks.
> > John Hockaday
> > GPO Box 378
> > Canberra ACT 2601
> > (02) 6249 9735
> enterprises
> includes the latest
> a copy and
> > _______________________________________________
Hi John,
Also refer http://trac.osgeo.org/geonetwork/ticket/74
Any changes to repository.xml.tem won't be picked up if you don't have
the Z39.50 server turned on prior to Simon fixing this ticket.
But it sounds like this shouldn't be a problem for you.
CraigJ
On Thu, 2009-06-04 at 14:28 +1000, Craig Jones wrote:
Hi John,
repository.xml.tem.
CraigJ
> Hi Craig,
> Thanks.
> John
> > To: Hockaday John
> > [SEC=UNCLASSIFIED]
> > Hi John,
> > other sites
> > server must
> > Cheers,
> > Craig Jones
> > Ph: +61 3 6226 8567
> > > Hi All,
> > > Thanks.
> > > John Hockaday
> > > GPO Box 378
> > > Canberra ACT 2601
> > > (02) 6249 9735
> > enterprises
> > includes the latest
> > a copy and
anzlicmet-l - discussion of the anzlic metadata entry tool (met)
to find out how to subscribe/unsubscribe etc send a blank email to anzlicmet-l-request@anonymised.com
to post send your email to anzlicmet-l@anonymised.com
Hi Craig,
Yes, I was directed to this Ticket #74 so I *do* have the local Z3950 switched on. Hence, your statement about "this shouldn't be a problem for you." is correct.
Thanks again for your prompt reply. It looks like you have been finding out similar information to me regarding this problem. ;--)
John
Sent: Thursday, 4 June 2009 2:51 PM
To: Hockaday John
Subject: RE: [GeoNetwork-devel] What does the
[SEC=UNCLASSIFIED]
Hi John,
CraigJ
> Hi John,
default install
files to see if
> repository.xml.tem.
> Cheers,
> CraigJ
> > Hi Craig,
> > Thanks.
> > John
> > > To: Hockaday John
> > > [SEC=UNCLASSIFIED]
> > > Hi John,
> > > other sites
Administration /
> > > server must
> > > Cheers,
> > > Craig Jones
> > > Ph: +61 3 6226 8567
> > > > Hi All,
> > > > Thanks.
> > > > John Hockaday
> > > > GPO Box 378
> > > > Canberra ACT 2601
> > > > (02) 6249 9735
> > > enterprises
> > > includes the latest
> > > a copy and
Virtualization.
Hi John,
That variable is coming from the server to the xslt. Seems like you are having problems with your repositories.xml.tem file though - I have been working on some minor changes to alter the way this is written in response to ticket #74 - I'll check out your earlier email that had a link to your repositories.xml.tem file.
Simon
From: John.Hockaday@anonymised.com [John.Hockaday@anonymised.com]
Sent: Thursday, 4 June 2009 1:47 PM
To: geonetwork-devel@lists.sourceforge.net; anzlicmet-l@anonymised.com
Subject: [GeoNetwork-devel] What does the {/root/gui/searchDefaults/remote} in the main-page.xsl file? [SEC=UNCLASSIFIED]
Hi All,
Thanks.
John Hockaday
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
Go to: Best Open Source Mac Front-Ends 2024
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi Simon,
Thanks for that. I have two repositories.xml.tem files. One for our internal setup which was included in the email that you mention, and one for the external setup. The latter is supposed to connect to the Australian Spatial Data Directory nodes. I'll make this latter repositories.xml.tem file available to you directly in another email.
Thanks for your offer of help.
John
From: Simon.Pigot@anonymised.com [mailto:Simon.Pigot@anonymised.com]
Sent: Thursday, 4 June 2009 5:13 PM
To: Hockaday John; geonetwork-devel@lists.sourceforge.net;
[SEC=UNCLASSIFIED]
Hi John,
Simon
[SEC=UNCLASSIFIED]
Hi All,
Thanks.
John Hockaday
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
includes the latest
