[GeoNetwork-devel] widgets UI, how are computed ResourceType values ?
Hi list,
Using search widgets UI, I wonder how the ResourceType fields values are computed.
Whether or not I set a metadata as “dataset” (in Hierarchy Level, gmd:MD_ScopeCode dataset), they seem to be always listed as datasets. For example, I’ve set up a metadata as “non geographic dataset”, and the Resource Type still doesn’t list me “non geographic datasets”. But when I perform a search for dataset resource types, I still get my “non geographic” metadata.
I don’t really understand how Resource Type works. It seems to mix gmd:MD_ScopeCode values with gmd:CI_PresentationFormCode values.
Can someone enlighten me about all this ?
Jean
Hi Jean,
check the type field in the index and adapt it to your needs.
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/index-fields.xsl#L549
HTH
Francois
2013/11/26 Jean Pommier (IGE) <jean.pommier@anonymised.com>
Hi list,
Jean
Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Hi François,
Thanks for the tip. Now I know how to change Resource Type’s behaviour. And understand what lies behind.
Still, I have a metadata I specificly set as “non geographic dataset” that seems to be indexed as dataset…
Any idea ?
I forgot to mention, I’m using 2.10.2 code.
Jean
2013/11/26 Francois Prunayre <fx.prunayre@anonymised.com.31…>
Hi Jean,
HTH
Francois
Hi list,
Jean
