Hi all
Just giving GeoNetwork a try as a potential CSW Server solution. First environment: Windows Server 2008 R2 x64, the screen after the files are transferred to the install directory is displaying blank, clicking next at this point freezes the installer. Second environment: Windows 7 x86, the installer correctly brings up the start menu screen, and the installation completes successfully.
Quick google suggests that whilst the izpack installer contains and references the shelllink.dll, it may need to include and reference shelllink_x64.dll for the start menu screen (and install process) to work in an x64 environment.
Could this be considered for a future build of the installer please, also is there a known workaround in the meantime?
Many thanks
Charles Laughton
Business Intelligence Officer
ICT Department
Newark and Sherwood District Council
(01636) 655823
charles.laughton@anonymised.com
Visit the new Newark and Sherwood District Council website www.newark-sherwooddc.gov.uk
…or scan me
Note:
This message is for the named person’s use only. It may contain confidential, proprietary or legally privileged information. No confidentiality or privilege is waived or lost by any mistransmission. If you receive this message in error, please immediately delete it and all copies of it from your system, destroy any hard copies of it and notify the sender. You must not, directly or indirectly, use, disclose, distribute, print, or copy any part of this message if you are not the intended recipient. NEWARK AND SHERWOOD DISTRICT COUNCIL and any of its subsidiaries each reserve the right to monitor all e-mail communications through its networks.
Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorized to state them to be the views of any such entity.
Senders and Recipients of email should be aware that, under the Data Protection Act 1998 and the Freedom of Information Act 2000 the contents may have to be disclosed in response to a request.
Newark and Sherwood District Council Legal Disclaimer.
Thank You.
