Sounds a good option, I’ll update that file in the develop branch.
On Tue, Feb 2, 2016 at 3:51 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
2016-02-02 15:39 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
Ok, lets remove it then in the develop branch only when ExtJs code is removed from there.
Maybe we could start flagging code to be removed by @deprecated annotation ? So when we decide to clean it will be easier to remember.
Francois
Jose García
On Tue, Feb 2, 2016 at 3:29 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi Jose,
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
2016-02-02 12:55 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
In the AngularJS UI seem https://github.com/geonetwork/core-geonetwork/blob/3.0.x/core/src/main/java/org/geonetwork/map/wmc/WmcServlet.java is not used.
But the ExtJS UI is still in GN 3.0.x and uses it. Is really supported or just for the ExtJs editor?
Looks like it is used in the mapviewer in Ext apps (see MapApp.js).
On my side, I started to warn users that ExtJS apps will be completely removed in future version (probably the next one 3.1+ ? to be discussed) and that existing apps/schemas needs to be migrated very soon.
Cheers.
Francois
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
GeoNetwork-devel mailing list
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
