hello again
i have now tried to fix the error in my wms, and i can now get an image from
this one:
http://www.kagi.fo/cgi-bin/mapserv.exe?map=c:/heimasidur/Kagi/Data/peturkirke.map
in my browser.
but still not in geonetwork, the way, as i tried before
do you know why ? (i am lost)
----- Original Message -----
From: "Mathieu Coudert" <mathieu.coudert@anonymised.com>
To: "Petur Kirke" <peturkirke@anonymised.com>
Cc: <geonetwork-devel@lists.sourceforge.net>
Sent: Thursday, November 02, 2006 9:03 AM
Subject: Re: [GeoNetwork-devel] wms
Hi Petur,
your WMS configuration is wrong. Indeed the Getcapabilities is ok but when
you
perform a Getmap, there a Mapserver Exception which is :
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msWMSLoadGetMapParams(): WMS server error. Image size out of range, WIDTH
and
HEIGHT must be between 1 and 2048 pixels.
</ServiceException>
</ServiceExceptionReport>
Mathieu
Quoting Petur Kirke <peturkirke@anonymised.com>:
> hello again, and thanks a lot for your help so far.
> i want to ask one more question.
> i am still trying, and hope to see a map from our wms server. When i am
on
> this site (popup):
http://lv-ternan.fds.fo:8080/geonetwork/intermap/srv/fo/mapServers.listServers
> To the right of "Map Server" I choose "- Other WMS server (specify
below)"
> and to the right of "Specify if other:" i write
http://www.kagi.fo/cgi-bin/mapserv.exe?map=c:/heimasidur/Kagi/Data/kortal.map
> Then i get a very nice screen with information about all the data and
> layers, and everything looks fine so far.
> Then i choose some layers, and push "OK" at the bottom.
> Than i get a nice screen where the map should arrive, but the image isnt
> there - or, there is an image, but only with the x at the top left
corner,
> that means it cannot show the image.
> Do you know what i have done wrong ? Can i see the error message
anywhere ?
> Sent: Tuesday, October 31, 2006 5:47 PM
>> It looks wrong Petur,
>> Delete the second paragraph, you just need to have one WMS protocol.
>> And the second one is not correct, the tag orName must be completed, it
>> corresponds to the layer name of your WMS layer (raster50cm in your
case).
>> Moreover, in the tag linkage, you don't need to give parameter such as
>> REQUEST,
>> LAYERS...
>> Mathieu
>> > i dont know if i have done it right, but everything is not working
yet,
> even
>> > if it looks better. This is what i have now:
>> > <onLineSrc>
>> > <linkage>http://www.kagi.fo</linkage>
>> > <protocol>WWW:LINK-1.0-http--link</protocol>
>> > <orName/>
>> > <orDesc>Kagin</orDesc>
>> > </onLineSrc>
>> > <onLineSrc>
<linkage>http://www.kagi.fo/cgi-bin/mapserv.exe?map=c:/heimasidur/Kagi/Data/
Kortal.map&VERSION=1.1.0&REQUEST=GetCapabilities&Service=WMS</li
>> > nkage>
>> > <protocol>OGC:WMS-1.1.1-http-get-capabilities</protocol>
>> > <orName/>
>> > <orDesc>mapfile</orDesc>
>> > </onLineSrc>
>> > <onLineSrc>
>> > Kortal.map</linkage>
>> > <protocol>OGC:WMS-1.1.1-http-get-map</protocol>
>> > <orName>raster50cm</orName>
>> > <orDesc>raster ...</orDesc>
>> > </onLineSrc>
>> > does it look ok or wrong ?
>> > Sent: Tuesday, October 31, 2006 3:13 PM
>> >> Edit your metadata in XML and then your can modify it.
>> >> Actually your metadata file in XML is like that :
>> >> <onLineSrc>
Kortal.map&VERSION=1.1.0&REQUEST=GetCapabilities&Service=WMS</linkage>
>> >> <orName/>
>> >> </onLineSrc>
>> >> you just have to change it in:
>> >> <onLineSrc>
>> >> <orName>Raster50cm</orName>
>> >> <orDesc>raster ... </orDesc>
>> >> </onLineSrc>
>> >> ( Select the button "metadata" and then clic on "XML View" and
"edit"
> your
>> >> metadata)
>> >> mathieu
>> >> > I am sorry, but where should i put this ?:
>> >> > <distTranOps>
>> >> > <onLineSrc>
>> >> > </onLineSrc>
>> >> > </distTranOps>
>> >> > We are using Mapserver as our WMS-server. Should i put this in the
> .map
>> > file
>> >> > ? Or somewhere in Geonetwork ?
>> >> > We are using IIS as webserver.
>> >> > To: <geonetwork-devel@lists.sourceforge.net>
>> >> > Sent: Tuesday, October 31, 2006 1:58 PM
>> >> >> Hi Petur,
>> >> >> The distribution part of tour metadata is not correct as well.
>> >> >> Try this way :
>> >> >> <distTranOps>
>> >> >> <onLineSrc>
>> >> >> </onLineSrc>
>> >> >> </distTranOps>
>> >> >> But you should configure your web server (apache?) using a proxy
> path
>> > to
>> >> > hide
>> >> >> your map directory (for instance http://www.kagi.fo/services? )
>> >> >> Mathieu
>> >> >> > Hi
>> >> >> > We are trying to build a geonetwork system here, and this is a
> link
>> >> >> > to somewhere on our system:
http://lv-ternan.fds.fo:8080/geonetwork/srv/fo/main.search?extended=off&remote=off&attrset=geo&any=myndakort&hitsPerPage=10
>> >> >> > Somewhere in the middle of this page, there is a botton called
>> >> >> > "Interactive Map".
>> >> >> > When i click on this button i get the error:
>> >> >> > "The requested operation could not be performed"
>> >> >> > What have we done wrong or what is missing ?
>> >> >> > Can anyone help ? or give some clue ?
>> >> >> > regards
>> >> >> > Petur Kirke
>> >> >> > Faroe Islands
>> >> >> Using Tomcat but need to do more? Need to support web services,
>> > security?
>> >> >> Get stuff done quickly with pre-integrated technology to make
your
> job
>> >> > easier
>> >> >> Download IBM WebSphere Application Server v.1.0.1 based on Apache
>> > Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
>> >> >> _______________________________________________
>> >> >> GeoNetwork-devel mailing list
>> >> >> GeoNetwork-devel@lists.sourceforge.net
>> >> >> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
>> >> >> GeoNetwork OpenSource is maintained at
>> >> > http://sourceforge.net/projects/geonetwork
