-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net [mailto:geonetwork-devel-bounces@lists.sourceforge.net] On Behalf Of Petur Kirke
Sent: 02 November 2006 13:26
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] wms
We are using Mapserver as WMS-server.
Welcome to the group
Does the geonetwork software support Mapserver ?
The answer is yes!
I’m using Mapserver to create web map services for the GeoNetwork node in FAO
----- Original Message -----
From: “Mathieu Coudert” mathieu.coudert@anonymised.com
To: “Petur Kirke” peturkirke@anonymised.com
Cc: geonetwork-devel@lists.sourceforge.net
Sent: Thursday, November 02, 2006 9:03 AM
Hi Petur,
your WMS configuration is wrong. Indeed the Getcapabilities is ok but
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?> <!DOCTYPE
when
you
perform a Getmap, there a Mapserver Exception which is :ServiceExceptionReport SYSTEM
“http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd”>
msWMSLoadGetMapParams(): WMS server error. Image size out of range,
WIDTH
and
HEIGHT must be between 1 and 2048 pixels.
Mathieu
Quoting Petur Kirke peturkirke@anonymised.com:
hello again, and thanks a lot for your help so far.
i want to ask one more question.
i am still trying, and hope to see a map from our wms server. When i
am
on
this site (popup):
http://lv-ternan.fds.fo:8080/geonetwork/intermap/srv/fo/mapServers.listServers
To the right of “Map Server” I choose “- Other WMS server (specify
below)”
and to the right of “Specify if other:” i write
http://www.kagi.fo/cgi-bin/mapserv.exe?map=c:/heimasidur/Kagi/Data/kortal.map
Then i get a very nice screen with information about all the data
and layers, and everything looks fine so far. Then i choose some
layers, and push “OK” at the bottom. Than i get a nice screen where
the map should arrive, but the image isnt there - or, there is an
image, but only with the x at the top left
corner,
that means it cannot show the image.
Do you know what i have done wrong ? Can i see the error message
anywhere ?----- Original Message -----
Sent: Tuesday, October 31, 2006 5:47 PM
Subject: Re: [GeoNetwork-devel] wmsIt looks wrong Petur,
Delete the second paragraph, you just need to have one WMS
protocol. And the second one is not correct, the tag orName must be
completed, it corresponds to the layer name of your WMS layer
(raster50cm in your
case).
Moreover, in the tag linkage, you don’t need to give parameter such
as REQUEST, LAYERS…Mathieu
i dont know if i have done it right, but everything is not
[http://www.kagi.fo](http://www.kagi.fo) WWW:LINK-1.0-http--link Kagin
working
yet,
even
if it looks better. This is what i have now:
Kortal.map&VERSION=1.1.0&REQUEST=GetCapabilities&Service=WMS</li
nkage>
OGC:WMS-1.1.1-http-get-capabilities
mapfile
Kortal.map
OGC:WMS-1.1.1-http-get-map
raster50cm
raster …
does it look ok or wrong ?
Sent: Tuesday, October 31, 2006 3:13 PM
Subject: Re: [GeoNetwork-devel] wmsEdit your metadata in XML and then your can modify it. Actually
your metadata file in XML is like that :
mapfile
you just have to change it in:
Kortal.map
Raster50cm
raster …
( Select the button “metadata” and then clic on “XML View” and
“edit”
your
metadata)mathieu
I am sorry, but where should i put this ?:
Kortal.map
Raster50cm
raster …
We are using Mapserver as our WMS-server. Should i put this in
the
.map
file
? Or somewhere in Geonetwork ?We are using IIS as webserver.
Sent: Tuesday, October 31, 2006 1:58 PM
Subject: Re: [GeoNetwork-devel] wmsHi Petur,
The distribution part of tour metadata is not correct as
well. Try this way :
Kortal.map
Raster50cm
raster …
But you should configure your web server (apache?) using a
proxy
path
to
hide
your map directory (for instance http://www.kagi.fo/services?
)Mathieu
Hi
We are trying to build a geonetwork system here, and this
is a
link
to somewhere on our system:
Somewhere in the middle of this page, there is a botton
called “Interactive Map”. When i click on this button i get
the error:“The requested operation could not be performed”
What have we done wrong or what is missing ?
Can anyone help ? or give some clue ?
regards
Petur Kirke
Faroe Islands
Using Tomcat but need to do more? Need to support web
services,
security?
Get stuff done quickly with pre-integrated technology to make
your
job
easier
Download IBM WebSphere Application Server v.1.0.1 based on
Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-devel mailing list
Using Tomcat but need to do more? Need to support web services, security? Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net
