Let me explain my case. I have done a xlst formatter to display xml metadata in html page (I know there’s a Groovy formatter for that, but doesn’t work well as changes the metadata displayed, removing namespaces from the header and adding to the xml elements, what make it useless and trying to fix it is not really clear).
So I added the xsl formatter to my schema and copied also these files to my schema to use highlight syntax:
2019-02-20 08:48:34,168 ERROR [geonetwork.wro4j] - Error occurred during a wro4j request handling
java.lang.IllegalArgumentException: Both ‘/XXXXX/web/src/main/webapp/WEB-INF/data/data/formatter/xml_view/highlight-json-xml.js’ and ‘org.fao.geonet.wro4j.ClosureRequireDependencyManager$Node@anonymised.com’ have the same provide id: highlight-json-xml
For sure I can check to reference the js/css from original paths in WEB-INF/data/data/formatter/xml_view, but wanted to create a schema with all required files and don’t rely in external resources.
It seems wro checks the formatter dir for css and js.
Your error is just about the file names, what is .cess ? I ddon’t exactly know if we can have same name for css and js, i would say yes, but maybe just change one file name and it should be fine ?
highlight-json-xml-css.cess
Other options is to remove wro check of formatterdir.
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Not really sure the reason to scan the schemas/formatter folders, but for now I managed to remove the files from the schema and just point to the global ones. Not optimal if the global files are removed in the future, but probably it’s unlikely and for now works fine.
Jose García
