Let me explain, I use GEONETWORK to generate metadata in XML format
complying with ISO 19139.
Then, with the file
WEB-INF/data/config/schema_plugins/ISO19139/index-fields.xsl I recovers the
values in the XML file.
Its looks like this:
(xml)
<spatialRepresentationType>
<MD_SpatialRepresentationTypeCode
codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_SpatialRepresentationTypeCode"
codeListValue = "vector" codespace = "ISOTC211 / 19115"> vector </
MD_SpatialRepresentationTypeCode>
</ spatialRepresentationType>
(xsl)
<xsl: for-each select = "gmd: spatialRepresentationType">
<Field name = "spatialRepresentationType" string = "{gmd:
MD_SpatialRepresentationTypeCode / @ codeListValue}" store = "true" index =
"true" />
</ xsl: for-each>
For now, no problem, I get the value of codelistvalue.
My problem is, I can not retrieve the associated value in the file
\WEB-INF\data\config\schema_plugins\ISO19139\loc\fre\codelists.xml I want to
use in the file apps\html5ui\js\ App-mini.js to display this value (label
and description) in the search result panel.
The associated value is:
<entry>
<code>vector</code>
<label>Vecteur</label>
<description>Donnée vecteur (point, ligne, polygone)</description>
</entry>
View this message in context: http://osgeo-org.1560.x6.nabble.com/XML-metadata-ISO19139-XSL-tp5156969.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
