[GeoNetwork-devel] XML Services in GeoNetwork version 3.4.x
Dear All,
Can someone please confirm that version 3.4.x of GeoNetwork includes the XML Services with equivalent functionality as existing on version 2.10.x ?
https://geonetwork-opensource.org/manuals/2.10.4/eng/developer/xml_services/index.html
It seems that there is no documentation for version 3 regarding this topic ?
If the interface exists, how the user shall be authenticated in the transactional requests of such interface (insert, update, deleted ) ? is it using the basic authentication on http header on the request to the GeoNewtork server ?
Thank you very much for your time and assistance,
BR,
Carlos Figueiredo
Technical Manager / Senior System Analyst
Defence & Security Systems
carlos.figueiredo@anonymised.com
Tel: +351.212945900
Mobile: +351. 937 673 523
Fax: +351.212945999
Rua Calvet Magalhães, 245
2770-153 Paço de Arcos · Portugal
www.edisoft.pt
A informação contida neste e-mail e quaisquer documentos anexos são propriedade da EDISOFT e poderão ser confidenciais. Se não for o destinatário pretendido, por favor, comunique-nos de imediato, enviando-nos esta mensagem de volta e destruindo-a em seguida. Fica desde já advertido de que é estritamente proibida qualquer revisão, divulgação, distribuição, cópia ou qualquer outra utilização deste e-mail.
The information contained in this e-mail and any attachments are the property of EDISOFT and may be confidential. If you are not the intended recipient, please notify us immediately, send this message back to us and destroy it. You are hereby notified that any review, dissemination, distribution, copying or otherwise use of this e-mail is strictly prohibited
Hi Carlos
GeoNetwork 3.x still supports that services as deprecated. Note that some of them can differ a bit as the doc is not well maintained.
There’s a new API that uses Swagger for documentation, you can access the test interface in http://SERVER/geonetwork/doc/api/
Jose García
On Thu, Oct 11, 2018 at 6:58 PM Carlos Figueiredo <carlos.figueiredo@anonymised.com> wrote:
Dear All,
BR,
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
GeoNetwork-devel mailing list
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
(attachments)
Hi José,
Thank you for the info.
Is there any other documentation available for the new swagger api ?
Best regards,
Carlos Figueiredo
carlos.figueiredo@…1177…
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Sent: sexta-feira, 12 de outubro de 2018 13:22
To: Carlos Figueiredo
Cc: Devel geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] XML Services in GeoNetwork version 3.4.x
Hi Carlos
Jose García
On Thu, Oct 11, 2018 at 6:58 PM Carlos Figueiredo <carlos.figueiredo@…1177…> wrote:
Dear All,
BR,
Error! Filename not specified.
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
(attachments)
Hi Carlos,
The documentation is on the endpoint that Jose pointed you out: http://SERVER/geonetwork/doc/api/
The API is a common REST API based on Java/Spring. Swagger is the documentation framework we use to generate the docs.
On Mon, Oct 15, 2018 at 11:34 AM Carlos Figueiredo <carlos.figueiredo@anonymised.com> wrote:
Hi José,
Best regards,
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
From: Jose Garcia [mailto:jose.garcia@anonymised.com]
Hi Carlos
Jose García
Dear All,
BR,
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
(attachments)
Thanx Maria.
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Sent: segunda-feira, 15 de outubro de 2018 10:38
Cc: Jose Garcia; Devel geonetwork-devel@lists.sourceforge.net
Hi Carlos,
On Mon, Oct 15, 2018 at 11:34 AM Carlos Figueiredo <carlos.figueiredo@…1177…> wrote:
Hi José,
Best regards,
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Hi Carlos
Jose García
Dear All,
BR,
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
(attachments)
Hi Carlos
Usually the new API services contain documentation for Swagger that is displayed in the Swagger page.
You can find also the code for the API services in https://github.com/geonetwork/core-geonetwork/tree/master/services/src/main/java/org/fao/geonet/api
Jose García
(attachments)
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
