[GeoNetwork-devel] XML validation
Hello.
  1. When I “Check” a Metadata, the Validation Window doesn’t show the Error messages only says “VALIDATION ERROR. Metadata is not valid.”
Is there any way of accessing to these errors information?
  1. Which is the version of the ISO19139 schema files used to validate Metadata in GN2.1.0?
  2. Also I have tried to Import some XML files validated with IME (the application developed in INTA) but I’ve got again this validation error message in Geonetwork.
That’s the reason of the 1st question, I would like to know the reason of this Error Validation Messages to debug the validation process.
Perhaps could be interesting for all of us the interchange of some XML files. I offer you my collaboration.
Thanks
Alberto Amaro
Metadata Project Manager
Earth Observation Department
INTA
___________________________________________________________________ Este mensaje se dirige exclusivamente a su destinatario y puede contener información privilegiada o CONFIDENCIAL. Si vd. no es la persona a quien se dirige este mensaje, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente por esta misma vía y proceda a su destrucción. This message is intended exclusively for its addressee and may contain information that is CONFIDENTIAL and protected by professional privilege. If you are not the intended recipient you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited by law. If this message has been received in error, please immediately notify us via e-mail and delete it. ___________________________________________________________________
