[GeoNetwork-devel] Your ideal GeoNetwork
as you know, we are designing geonetwork 3. The main issues here are to
understand the real needs of the users and to address these issues we need
some feedback from you.
The purpose of this email is to get your idea of your ideal geonetwork. How
it should designed, what features it should have and so on. I would like to
subdivide the requirements in 2 classes:
- those closely related to the metadata format itself (stuff like the use of xlink
  for contacts, use of metadata hierarchies, ISO services etc...)
- general requirements (features, user interface, modules, protocols)
While it is easy for us to address the second class we have some problems
with the first one. I would like to receive a lot of feedback from you here,
exspecially from those of you (like John Hockaday) who have a deep understanding
of the metadata formats like the ISO one. The question is: how would you
design your geonetwork to face your needs?
Many thanks in advance,
Hi Andrea, some ideas ...
- How to manage multilingual metadata ? This will certainly be useful for
such initiative as INSPIRE in Europe as the commission will ask member
states to produce metadata ... How to deal with this in search, edit,
translation ... I know some projects which looked a bit into that
(http://www.idee.es/sdiger/). Is that a need for FAO also ?
- following John Hockaday remark on the user interface design maybe we could
also work on how to get automatic metadata from the datasets ? Query the
WebMapservice to get the extent, the projection ..., the WebFeatureService
to get the structure, ... And in a local network, grab information from a
RASTER file ... using GeoTools ? Gdal ...
- Configuring geonetwork to use LDAP for users and groups ?
- Use of an XML Native DB (such as eXist or Xindice ...) ? This could be
useful to query XML doc and update some parts of the XML using a Xquery
language. Geonetwork is using Lucene to query metadata which is really nice
but in some way XML DB could make insert/update/basic search of XML easier
... Some of those have an xlink support I guess
- cache XML ... Geonetwork is spending time to do XSL transformation and
maybe geonetwork is doing many time the same things ... Is there any way to
do XML cache for that ?
Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de Andrea
Carboni
Envoyé : lundi 22 janvier 2007 17:52
À : geonetwork-devel@lists.sourceforge.net
Objet : [GeoNetwork-devel] Your ideal GeoNetwork
xlink
understanding of the metadata formats like the ISO one. The question is: how
would you design your geonetwork to face your needs?
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's
Techsay panel and you'll get the chance to share your opinions on IT &
business topics through brief surveys - and earn cash
GeoNetwork-devel mailing list
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
Hi Francois,
many thanks for your feedback. Here are my answers:
This is a big issue, but for now we don't know how to address it.
Good suggestion.
Yes, already planned. This feature has been asked by many users.
We were looking at some xml-dbmss. I didn't know about eXist so I had a look
at it and it seems to be the 'definitive' one: can manage milions of metadata,
supports XACML and has many interesting features. Thanks!!!
This is a good point. Are you having problems with performances? Beside the
first load of the home page, the speed seems reasonable.
Francois
Carboni
xlink
Hi Andrea,
Carboni
Envoyé : lundi 29 janvier 2007 12:43
Objet : Re: [GeoNetwork-devel] Your ideal GeoNetwork
Hi Francois,
for such initiative as INSPIRE in Europe as the commission will ask
member states to produce metadata ... How to deal with this in search,
edit, translation ... I know some projects which looked a bit into
that (http://www.idee.es/sdiger/). Is that a need for FAO also ?
# Maybe two solutions, have on metadata in each language or
# like in the skos format we used for thesaurus add a "lang" attribute on
each element we need to translate
# <topicCat lang="en">Blabla</topicCat><topicCat
lang="fr">BlablaFr</topicCat> ... That way you could translate only part of
the metadata which need to be translated ... Is there any comments on that
on the ISO standards ?
# ... Then link the user interface with a translation service :wink:
could also work on how to get automatic metadata from the datasets ?
Query the WebMapservice to get the extent, the projection ..., the
WebFeatureService to get the structure, ... And in a local network,
grab information from a RASTER file ... using GeoTools ? Gdal ...
Good suggestion.
# I had a try with linking the GUI with a WMS service ... That's quite easy
with the Ajax we have on the client side now.
be useful to query XML doc and update some parts of the XML using a
Xquery language. Geonetwork is using Lucene to query metadata which is
really nice but in some way XML DB could make insert/update/basic
search of XML easier ... Some of those have an xlink support I guess
metadata, supports XACML and has many interesting features. Thanks!!!
and maybe geonetwork is doing many time the same things ... Is there
any way to do XML cache for that ?
# No I'm not, but it could certainly be better ... Cache could also be set
up at the webserver level anyway.
Francois
Francois
Andrea Carboni Envoyé : lundi 22 janvier 2007 17:52 À :
to understand the real needs of the users and to address these issues
we need some feedback from you.
geonetwork. How it should designed, what features it should have and
so on. I would like to subdivide the requirements in 2 classes:
use of xlink
problems with the first one. I would like to receive a lot of feedback
from you here, exspecially from those of you (like John Hockaday) who
have a deep understanding of the metadata formats like the ISO one.
The question is: how would you design your geonetwork to face your needs?
--- Take Surveys. Earn Cash. Influence the Future of IT Join
SourceForge.net's Techsay panel and you'll get the chance to share
your opinions on IT & business topics through brief surveys - and earn
cash
DEV _______________________________________________
Hi Andrea, regarding "your ideal geonetwork" we could also work on
supporting xsl version 2.0
... It's not supported by the parser for now ?
Francois
Carboni
Hi Francois,
Good suggestion.
Francois
use of xlink
cash
Hi Francois,
I agree with you. I'm studying xsl 2.0 and I have already planned its use.
Francois
Carboni
Hi Francois,
Good suggestion.
> Francois
> Hi all,
> use of xlink
> Andrea
> cash
opinions on IT & business topics through brief surveys-and earn cash
