[GeoNetwork-devel] Your ideal GeoNetwork
Hi Andrea, François,
> - How to manage multilingual metadata ? This will certainly be useful
> for such initiative as INSPIRE in Europe as the commission will ask
> member states to produce metadata ... How to deal with this in search,
> edit, translation ... I know some projects which looked a bit into
> that (http://www.idee.es/sdiger/). Is that a need for FAO also ?
This is a big issue, but for now we don't know how to address it.
# Maybe two solutions, have on metadata in each language or
# like in the skos format we used for thesaurus add a "lang" attribute on
each element we need to translate
# <topicCat lang="en">Blabla</topicCat><topicCat
lang="fr">BlablaFr</topicCat> ... That way you could translate only part of
the metadata which need to be translated ... Is there any comments on that
on the ISO standards ?
# ... Then link the user interface with a translation service :wink:
For codes like topicCategory, scopeCode etc., ISO allows for the definition of alternative expressions in other languages, like in the example (see attachment, taken directly from ISO19139 XSDs).
Does this answer your question?
Tim
_________________________________________________________________
Looking for an old friend? You may find him in your friends' friends list ! http://spaces.live.com/default.aspx?page=Ed01&ss=True
(attachments)
ML_gmxCodelists.xml (43 KB)
Hi Francois,
for codelists I agree with Tim: we can have a fixed vocabulary whose codes
are translated by a client application. For the other elements, I don't think
that adding a 'lang' attribute makes it pass the validation (so says the schema).
I'm currently reading the iso19115:2003 spec, maybe something will come out.
Tim
Hi Andrea, in the ISO19115 spec, multi-languages handling is presented in
Annex J.
WMO proposal for their profil :
http://www.wmo.ch/web/www/WDM/IPET-MI-II/MultilanguageSupport.ppt
Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de Andrea
Carboni
Envoyé : mardi 30 janvier 2007 14:22
À : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Your ideal GeoNetwork
Hi Francois,
think that adding a 'lang' attribute makes it pass the validation (so says
the schema).
> > useful for such initiative as INSPIRE in Europe as the commission
> > will ask member states to produce metadata ... How to deal with
> > this in search, edit, translation ... I know some projects which
> > looked a bit into that (http://www.idee.es/sdiger/). Is that a need
for FAO also ?
># Maybe two solutions, have on metadata in each language or # like in
>the skos format we used for thesaurus add a "lang" attribute on each
>element we need to translate # <topicCat
>part of the metadata which need to be translated ... Is there any
>comments on that on the ISO standards ?
Tim
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's
Techsay panel and you'll get the chance to share your opinions on IT &
business topics through brief surveys - and earn cash
GeoNetwork-devel mailing list
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
