[GeoNetwork-users] 2.10.3 -> 3.2.1 upgrade, how to handle data folder?
We've a jetty9 running an instance of Geonetwork 2.10.3 on a Windows server
with a Postgresql db.
The documentation isn't available it seems:
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/updating/manual-update.html
so I found from a prior thread on a similar subject that
1. Updating the database via the updater sql scripts
2. Update the application and edit WEB-INF\config-db\postgres.xml,
jdbc.properties, config-node\srv.xml to match the db details.
3. Restore the old data folder
Just doing 2 (removing the old /geonetwork folder in webapps and putting the
3.2.1 one there) and restarting jetty) seems to have updated the db, it
takes a few minutes but then the interface does show the approximate number
of datasets and user logins are working. It does complain about
/geonetwork/srv/eng/small.bmp missing everywhere but that isn't fatal.
Trying to edit a dataset shows the toolbar and then white. Viewing works.
But anyway, to reinstate attachments and the like we need our old data
folder.. so deleting the new web-inf\data and reinstating the old one-
config, data, removed, index. Delete the new \spatialindex and delete the
spatialindex.shp in index. (otherwise the application fails to start, it
misses some _id column, several exclamation marks, in the shp)
Restart ... we have thumbnails even, but editing still white.
Two 404s when loading the edit screen refer to iso19139 ..so I noticed that
the 3.2.1 data\config has groovy and other things not found in our 2.10.3
config. Delete the old \config from the new application and reinstate the
new \config ->
No more 404 but the edit view still won't load. The console shows Error:
JSON.parse: expected ',' or '}' after property value in object at line 1
column 1658 of the JSON data and a few following errors.
How does one go about performing this upgrade?
I could export all metadatarecords and import them in a new clean
installation, probably, but then all categories and groups would need to be
recreated, plus potentially a few other things.
Thanks for any advice.
View this message in context: http://osgeo-org.1560.x6.nabble.com/2-10-3-3-2-1-upgrade-how-to-handle-data-folder-tp5323890.html
