[GeoNetwork-users] A few issues with GeoNetwork 2.6.4
Hi
I have noticed a few issues with GeoNetwork 2.6.4 on Tomcat, Windows 2008
R2:
- When I select "My metadata" and then the delete button for a specific data
set, nothing happens. No action, no error message. If I instead go to "Home"
- Search and hit the delete button, I am able to delete it.
- Nothing happens when I select "My metadata" - Other actions - Privileges.
If I use Home - Search - Other actions - Privileges, the desired window
opens.
- In "Sort Templates" - nothing happens when I hit the save button.
Are these issues known? Perhaps I am missing something?
Best regards,
Magnus
View this message in context: http://osgeo-org.1560.n6.nabble.com/A-few-issues-with-GeoNetwork-2-6-4-tp4620598p4620598.html
A few more:
- When I do Home – Search – Select a data set (check box) – actions on
selection, I get ”No selection, select one metadata first.”, even though one
metadata is selected. Sometimes it works and sometimes I get this error
message.
- Why is there so much unused space when listing the metadata? There are
quite a few rows not being used, which makes the page look less
professional.
- When I try, for example, “Print to PDF”, I get the error message
“OutOfMemoryError : PermGen space”. I have tried increasing the memory in
tomcat6w.exe, but GeoNetwork wouldn´t start with 1024 MB (initial memory),
so I set it to 768 MB. How do I assign more memory in order to help
GeoNetwork?
Magnus
View this message in context: http://osgeo-org.1560.n6.nabble.com/A-few-issues-with-GeoNetwork-2-6-4-tp4620598p4620750.html
This is strange: When I hit Administration – My Metadata – select a record –
Other actions (at the top of the page), the drop down list with actions
shows. However, when I hit Other actions at the bottom of the page, nothing
happens.
I will try to report these bugs on http://trac.osgeo.org/geonetwork/ .
Magnus
View this message in context: http://osgeo-org.1560.n6.nabble.com/A-few-issues-with-GeoNetwork-2-6-4-tp4620598p4624662.html
Hi
Some of the issues you report should be solved in the branch after 2.6.4
release.
* See http://trac.osgeo.org/geonetwork/ticket/528 for MyMetadata issues.
* About Why is there so much unused space when listing the metadata? I see
a commit possibly related to this, in some cases render in Firefox at least
was not ok
* About pdf print, possibly related
http://trac.osgeo.org/geonetwork/ticket/629
Before adding the issues in trac, please if you can try with nightly build
installer for branch (http://nightlybuild.geonetwork-opensource.org/branch)
as contains also all fixes done in branch after 2.6.4 release, and verify
if issues still happen. If thats the case, please create them in trac.
Note that the installer is not for production use, we should release 2.6.5
in some moment with all these fixes.
Jose García
On Fri, Mar 16, 2012 at 11:04 AM, johnrobot <johnrobot@anonymised.com> wrote:
happens.
Magnus
This SF email is sponsosred by:
Try Windows Azure free for 90 days Click Here
http://p.sf.net/sfu/sfd2d-msazure
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Hi Jose
Thank you for your suggestions. I will try the latest build.
Magnus
View this message in context: http://osgeo-org.1560.n6.nabble.com/A-few-issues-with-GeoNetwork-2-6-4-tp4620598p4627590.html
