[GeoNetwork-users] A few minor customisation/localisation issues
Hello, everyone
I've come against a few (hopefully, minor) customisation/localisation issues
that I can't seem to solve (even Agent Ransack is letting me down on these):
- I've added the metadata changeDate to the 'extract' PDF from the search
page, but I can't seem to get it to display in dd/mm/yyyy format. I've tried
DateTime.js and a few other likely suspects, with no joy. Every other date
shows up as dd/mm/yyyy.
- I need to change the setting for the logo in the 'full' PDF that exports
from the metadata record view. No problem with the 'extract' settings, but I
can't find the equivalent of the *.fop files from ...\xslt\services\pdf for
the 'full'PDF.
- The topic categories on the 'home' page need to be sorted in alphabetic
order, rather than by the number of records, so the topics always show in
the same place (if they have records), but I can't find the way to do this.
I'm hoping someone else has come across these, and found a solution. Any
help would be appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/A-few-minor-customisation-localisation-issues-tp5256128.html
