Is there any modulable javascript/ajax web client widget for GeoNetwork? Or just a CSW-T client? Should be easily customizable and easily embeddable in an existing web page?
I'm searching for something like OpenLayer but for the CSW-T interface. By modulable I mean I can activate only some functionalities like display of some metadata fields, edit of some metadata fields, search...
If not, how hard is it to customize GeoNetwork default HTML interface and can it be embedded, like a widget, in an existing web page?
Pierre
Hello Pierre,
2012/5/8 Pierre Racine <Pierre.Racine@anonymised.com>:
You could have a look to the widget UI [1] & [2] which is available in
trunk. It mainly uses GN services but some widgets could use CSW (for
searching for example). For editing, GN services are used.
HTH.
Francois
[1] http://trac.osgeo.org/geonetwork/wiki/proposals/WidgetsBasedGui
[2] http://geonetwork-opensource.org/manuals/trunk/eng/widgets/index.html
Pierre
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
