[GeoNetwork-users] A query about metadata and the Date Line
Hi
I am interested in entering metadata into my geonetwork node where the
bounding extents of the data crosses the 180° meridian
I have successfully created the metadata which has extents of W: 175 and
E-175
However when I then go to do a spatial search it won't allow me to use those
coordinates - says West must be less than East, which is fair enough.
However if I do a spatial search of W: -180 E: -175 it doesn't find the
metadata record - it will only spatially find the record if I enter W: -180
E: 180
The only solution I can come up with is to add two extents to the metadata
split at the meridian, is this the best solution or is there any other
advice anyone can give me regarding this issue.
Many thanks for your help
Caroline Levey
Senior GIS Developer
SeaZone Solutions Limited
This email and any files transmitted with it are confidential
and intended only for the use by the addressee. If you
receive this email by mistake pleases notify SeaZone
immediately.
Hi Caroline,
Unfortunately, I don't have an immediate answer to you question, however ...
I seem to remember that the east and west bounding longitudes were limited to a range of -180 to 360. This allowed one to set a bounding box over the international date line. EG. 170 West to 190 East. However, the current ISO 19115 standard shows the range for the east and west bounding longitudes to be -180 to 180.
This would indicate that a search over the international date line would have the west bounding longitude to be greater than the east bounding longitude. EG. 170 West and -170 East would be a 20 degree bounding box over the international date line.
If GeoNetwork doesn't allow this type of search, as you indicated, then it is limiting the searching requirements of living in a geoidal world. Are the GN developers 'flat earthers'? ;--) (Please note the joke developers.)
In this case the standard allows searches over the international date line but the implementing software doesn't.
May I suggest that the GN developers apply this change so before the release of 2.4? It may assist in searches over the Pacific Ocean.
Thanks.
John
-----Original Message-----
From: Caroline Levey [mailto:Caroline.Levey@anonymised.com]
Sent: Friday, 12 June 2009 5:51 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] A query about metadata and the Date Line
Hi
W: 175 and
E-175
me to use those
doesn't find the
enter W: -180
E: 180
the metadata
Caroline Levey
immediately.
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
GeoNetwork-users mailing list
