[GeoNetwork-users] add additional Metadata Hierarchy Levels to the Code List provided in GeoNetwork
Hi there
I would like to add additional Metadata Hierarchy Levels to the Code List
provided in GeoNetwork. In particular, I would like to be able to select
from the list provided in the
http://www.osdm.gov.au/Metadata/ANZLIC+metadata+resources/ANZMet+Toolkit+(final+draft+-+07.2009)/default.aspx
ANZMET Lite tool . The list in the ANZMET Lite tool is based on the code
list in ISO 19115 (excluding "series) and then adds: mode/session; document;
profile; data repository; code list, and; project.
How can I add the additional names available in the ANZMET Lite tool
(including "series") to the Metadata Hierarchy Levels code list provide by
GeoNetwork?
I'm not a programmer - so please explain in Plain English as much as
possible :slight_smile:
Thanks in anticipation!
John
View this message in context: http://osgeo-org.1803224.n2.nabble.com/add-additional-Metadata-Hierarchy-Levels-to-the-Code-List-provided-in-GeoNetwork-tp6248720p6248720.html
Hi John,
That codeList extension was a result of an email thread that I sent out to the ozmeta-l and asdi-l lists a year or two ago. These were the two lists that I know of that would get to the largest spatial metadata community. Unfortunately the ozmeta-l list has closed and I believe that the asdi-l list is expected to close. Hence we will not have a national or even Australasian discussion list to discuss these matters. I'm keen to see how ANZLIC intends to address this matter but that is another issue ... ;--)
There may be an archive of that email thread on the ANZLIC or ERIN web sites.
The resulting code list is at URL:
http://asdd.ga.gov.au/asdd/profileinfo/
Look at the sixth dot point in the second numbered list on that page. It is identified as "Geoscience Australia's ScopeCode codelist ..." because we did not develop a profile (as we should have done but we had no where to register it so it wasn't worth doing) and that it was not officially endorsed by ANZLIC. I needed to add some values ASAP and so I went to the spatial metadata community to get approval. There was no objection to the added values and definitions.
The format is in ISO 19139 CT_CodelistCatalogue XML format. This is the official way of providing and extending codeLists. You could add more content to a copy of this and make it available on your own we site. If you don't make it publically available on a web site then people will not be able to validate the MD_ScopeCode values in metadata that uses your new list.
However this will not address the issue of getting it into GeoNetwork. I will leave that to others.
I'm sorry that this is a bit more technical than you wanted but it has to be for it to work properly.
I hope it helps.
John H.
-----Original Message-----
Sent: Thursday, 7 April 2011 3:45 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] add additional Metadata Hierarchy
Hi there
the Code List
able to select
et+Toolkit+%28final+draft+-+07.2009%29/default.aspx
on the code
list provide by
GeoNetwork?
John
-Hierarchy-Levels-to-the-Code-List-provided-in-GeoNetwork-> tp6248720p6248720.html
Xperia(TM) PLAY
It's a major breakthrough. An authentic gaming
smartphone on the nation's most reliable network.
And it wants your games.
http://p.sf.net/sfu/verizon-sfdev
GeoNetwork-users mailing list
Thank you John - much appreciated.
I suspect I am in a similar situation to you, i.e. I need to add some values ASAP (without necessarily waiting for this extension to the official endorsed by ANZLIC). However, I've noted your point about needing to get this extension to the code list officially endorsed by ANZLIC. To this end I've discussed with Richard and would be interested in your thoughts about how we might get this official endorsement... From what I understand, there is some reference to the extended code list via http://asdd.ga.gov.au/asdd/profileinfo/ - however, this extended code list has not (yet) been coded into XML.
Thanks again and have a good weekend :slight_smile:
John
From: john.hockaday@anonymised.com [mailto:john.hockaday@anonymised.com]
Sent: Thursday, April 07, 2011 6:34 PM
To: John Forne; geonetwork-users@lists.sourceforge.net
Subject: RE: [GeoNetwork-users] add additional Metadata Hierarchy Levels to the Code List provided in GeoNetwork [SEC=UNCLASSIFIED]
Hi John,
I hope it helps.
John H.
Subject: [GeoNetwork-users] add additional Metadata Hierarchy Levels
Hi there
List provided in GeoNetwork. In particular, I would like to be able to
select from the list provided in the
code list in ISO 19115 (excluding "series) and then adds:
provide by GeoNetwork?
John
-Hierarchy-Levels-to-the-Code-List-provided-in-GeoNetwork-> 48720.html
Xperia(TM) PLAY
It's a major breakthrough. An authentic gaming smartphone on the
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info@anonymised.com) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
