Hi everybody,
I have add new language in geonetwork, all is ok,
but I don't see category-list in left of home page.
what's the file for traslation?
thank!
emanuele
_________________________________________________________________
Doretta è In linea: vieni a conoscerla su Messenger!
http://www.doretta82.it/banner/index.html
Hi Emanuele,
categories are now editable and their localized strings are inside
the database. To localize them, you have to edit the file:
gast/setup/.../CategoriesDes.ddf
Hi everybody,
thank!
emanuele
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-users mailing list
Hi Andrea,
about this:
(1) the file CategoriesDes.ddf contains a mapping from ids, to language and
the localisation string. This means that to do this localisation you
actually have to look into the database to know these IDs ?
(2) is it necessary to restart the application for changes to this file to
be effective?
thank you,
Heikki Doeleman
Andrea Carboni-2 wrote:
Hi Emanuele,
Hi everybody,
thank!
emanuele
View this message in context: http://www.nabble.com/add-language-in-geonet-2.1-tf4519028s18419.html#a13604609
Sent from the geonetwork-users mailing list archive at Nabble.com.
The localization Andrea suggests will work when you set up the database from scratch. Not when you want to change categories in a system already installed. In that case you have to use the localization function in the web interface under administration. Attached is a screenshot of that interface.
Ciao,
Jeroen
(Attachment Picture 2.png is missing)
(attachments)
