I tried to add a new search fields in the "WEB-INF/data/config/schema_plugins/iso19139/index-fields/default.xsl file as indicated in the following lines
But if I try then to perform a query it is not working.
Could you help me showing what I'm doing wrong?
Thanks in advance
Bartolomeo
According to regulation (EU) 2016/679 this transmission is intended only for the
use of the addressee and may contain confidential information. If you receive
this transmission in error, please notify the sender immediately by email and
delete all copies of this message and any attachments.
That change is only to index a new Lucene field cloud_coverage_percentage
and should be possible to use it in the q service for example. But you'll
need first to reindex the catalogue.
But if I'm understanding you correctly, you want to display that field in
the search results or use it as a filter in the UI search form? Previous
change is not enough for that.
Jose García
On Thu, Sep 27, 2018 at 4:58 PM Ventura Bartolomeo <
bartolomeo.ventura@anonymised.com> wrote:
Thanks in advance
Bartolomeo
for the
receive
and
