The gbif profile of eml is already present as Jose mentions, though it looks much simpler than the full eml schema (https://knb.ecoinformatics.org/#external//emlparser/docs/index.html), but it may be a good place to start. We had a requirement to support indexing and searching of eml-gbif a few years ago, hence the eml-gbif schema in GeoNetwork. I'd be keen to hear about your (or any) attempts to integrate the full eml schema into GeoNetwork!
Simon
________________________________________
Sent: Wednesday, 12 November 2014 6:19 PM
To: cbeltran
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Add schema EML on geonetwork
Hi
To add support for a new schema you need to develop it in GeoNetwork, it's
not just adding the xsd. You can find some documentation about this here:
You have also a metadata profile repository with some metadata profiles
already available: GitHub - geonetwork/schema-plugins , where I
see this one:
schema-plugins/eml-gbif at develop · geonetwork/schema-plugins · GitHub , but
not sure if it's the same as the one you point (eml).
You can clone the repository GitHub - geonetwork/schema-plugins
and copy the folder eml-gbif to you GeoNetwork instalation
geonetwork/WEB-INF/data/config/schema_plugins
Jose García
On Wed, Nov 12, 2014 at 12:29 AM, cbeltran <cbeltran@anonymised.com> wrote:
good night
I need help to add a new scheme in geonetwork, how is it done ??? what are
the requirements ???
In particular I need to include the schema (eml) located at the following
url but unfortunately no longer online, if anyone has it I thank I can
indicate where to find it.
https://knb.ecoinformatics.org/#external//software/dist
Thank you for your help
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Add-schema-EML-on-geonetwork-tp5172454.html
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
