Using GN 2.6.3 a '???' is added to the 'name' column of the 'sources' table whenever a single XML file or multiple XML (batch) file import is done. It appears to be because the source XML file has no siteName so the program inserts a '???' instead for the name column and the local siteID (uuid) into the uuid column. The side effect of this bug is that a '???' appears on the Advanced Search->Restrict To->Catalog drop down list which is confusing as this list will already have an entry containing the local siteName.
I shown this issue to Craig Jones a BlueNet Geonetwork developer in Australia. Craig has kindly written a patch to fix this issue. The patch has been tested and it works with the BlueNet Geonetwork and should work with
trunk as the code base is the same.
Simon
________________________________________
Sent: Monday, 24 January 2011 9:59 AM
To: geonetwork-devel@lists.sourceforge.net
Cc: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-devel] '???' added to 'sources' table on single/multiple XML file import
Hi GN Developers,
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
GeoNetwork-devel mailing list
