[GeoNetwork-users] Adding a language
Hello,
I added the Romanian language but then I search my ISO19139 metadata
(added in ro/en/ru) with RO language selected the results are in EN.
If I search in RU the results are in RU. My question is how do I make
the search display results in RO if the metdata is available in RO.
Steps I followed (http://trac.osgeo.org/geonetwork/wiki/HowToTranslate):
First I created a record in languages table:
Then added new records to *Des tables
INSERT INTO categoriesdes (SELECT iddes, 'ro' as langid, label FROM
categoriesdes where langid = 'en');
INSERT INTO groupsdes (SELECT iddes, 'ro' as langid, label FROM
groupsdes where langid = 'en');
INSERT INTO isolanguagesdes (SELECT iddes, 'ro' as langid, label FROM
isolanguagesdes where langid = 'en');
INSERT INTO operationsdes (SELECT iddes, 'ro' as langid, label FROM
operationsdes where langid = 'en');
INSERT INTO regionsdes (SELECT iddes, 'ro' as langid, label FROM
regionsdes where langid = 'en');
and then I "copied" en folder in every folder with xml definitions to ro.
This step did not work for me:
ISO19139 / Multilingual metadata because
xml/schemas/iso19139/present/metadata-iso19139-utils.xsl file does not
exist.
Best Regards,
Iacovlev Pavel
Found the file in another folder: web/geonetwork/xsl/metadata-iso19139-utils.xsl
Now search works as expected
On Fri, Jul 6, 2012 at 9:31 AM, Pavel Iacovlev <iacovlev.pavel@anonymised.com> wrote:
Hello,
exist.
Best Regards,
Iacovlev Pavel
I have another problem with my newly added language, when I make the
following request to CSW:
http://geoportal.md:8080/geonetwork/srv/ro/csw?REQUEST=GetCapabilities&SERVICE=CSW
I get the follow exception (Cannot load/process capabilities):
2012-07-10 10:12:12,831 INFO [jeeves.service] - -> dispatching to
output for : csw
2012-07-10 10:12:12,831 INFO [jeeves.service] - -> writing xml for : csw
2012-07-10 10:12:12,831 DEBUG [jeeves.service] - Service xml is :
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
  <ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>Cannot load/process capabilities</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
2012-07-10 10:12:12,831 INFO [jeeves.service] - -> output ended for : csw
2012-07-10 10:12:12,831 INFO [jeeves.service] - -> dispatch ended for : csw
I guess I am missing some file or configuration settings, anybody can
point me in the right direction ?
On Fri, Jul 6, 2012 at 10:32 AM, Pavel Iacovlev
Hello,
exist.
Best Regards,
Iacovlev Pavel
Hi Pavel
Did you add also Romanian to Languages table?
Check also output.log, should contain some StackTrace that helps to
identify the issue.
Jose García
On Tue, Jul 10, 2012 at 9:17 AM, Pavel Iacovlev <iacovlev.pavel@anonymised.com>wrote:
output for : csw
csw
  </ows:Exception>
csw
csw
wrote:
>> Hello,
ro.
>> exist.
>> Best Regards,
>> Iacovlev Pavel
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Yes, I have added according to the following doc:
The language works fine otherwise, I can search in RO and see it in
the languages list.
Here is the full log of the error: http://pastie.org/4230252
On Tue, Jul 10, 2012 at 10:21 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Pavel
Check also output.log, should contain some StackTrace that helps to identify
the issue.
Jose García
output for : csw
csw
  </ows:Exception>
csw
csw
>> Hello,
>> Steps I followed
>> ro.
>> exist.
>> Best Regards,
>> Iacovlev Pavel
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
P.S. The CSW GetRecord request works for RO language.
On Tue, Jul 10, 2012 at 10:25 AM, Pavel Iacovlev
the languages list.
Hi Pavel
the issue.
Jose García
output for : csw
csw
  </ows:Exception>
csw
csw
>> Hello,
>> Steps I followed
>> ro.
>> exist.
>> Best Regards,
>> Iacovlev Pavel
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Pavel
I see a NullPointerException, but no StrackTrace, did you check output.log
file (or catalina.out if using Tomcat) instead of geonetwork.log, hopefully
should contain the StrackTrace to identify where is the problem.
Jose García
On Tue, Jul 10, 2012 at 9:30 AM, Pavel Iacovlev <iacovlev.pavel@anonymised.com>wrote:
> the languages list.
wrote:
>> Hi Pavel
identify
>> the issue.
>> Regards,
>> Jose García
>>> output for : csw
for :
>>> csw
>>> </ows:Exception>
for :
>>> csw
for :
>>> csw
>>> >> Hello,
EN.
make
>>> >> Steps I followed
FROM
to
>>> >> ro.
not
>>> >> exist.
>>> >> Best Regards,
>>> >> Iacovlev Pavel
Discussions
malware
>>> _______________________________________________
on
>> Jose García
>> GeoCat bv
>> Veenderweg 13
>> 6721 WD Bennekom
>> The Netherlands
>> http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
FIXED, The doc says to update only the *Des tables, but there is one
more table that needs updating "cswservercapabilitiesinfo".
INSERT INTO cswservercapabilitiesinfo VALUES ('41','ro','title','');
INSERT INTO cswservercapabilitiesinfo VALUES ('42','ro','abstract','');
INSERT INTO cswservercapabilitiesinfo VALUES ('43','ro','fees','');
INSERT INTO cswservercapabilitiesinfo VALUES ('44','ro','accessConstraints','');
All works fine now.
On Tue, Jul 10, 2012 at 10:30 AM, Pavel Iacovlev
the languages list.
Hi Pavel
the issue.
Jose García
On Tue, Jul 10, 2012 at 9:17 AM, Pavel Iacovlev <iacovlev.pavel@anonymised.com.>
output for : csw
csw
  </ows:Exception>
csw
csw
>> Hello,
>> Steps I followed
>> ro.
>> exist.
>> Best Regards,
>> Iacovlev Pavel
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Is it ok that I update the wiki with to inconsistencies I found ?
The cswservercapabilitiesinfo table, and the incorrect path
"xml/schemas/iso19139/present/metadata-iso19139-utils.xsl" should be
"xsl/metadata-iso19139-utils.xsl"
On Tue, Jul 10, 2012 at 11:05 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Pavel
Jose García
> the languages list.
> wrote:
>> Hi Pavel
>> identify
>> the issue.
>> Regards,
>> Jose García
>>> output for : csw
>>> for :
>>> csw
>>> </ows:Exception>
>>> for :
>>> csw
>>> for :
>>> csw
>>> >> Hello,
>>> >> metadata
>>> >> EN.
>>> >> make
>>> >> Steps I followed
>>> >> FROM
>>> >> to
>>> >> ro.
>>> >> not
>>> >> exist.
>>> >> Best Regards,
>>> >> Iacovlev Pavel
>>> Discussions
>>> malware
>> on
>> Jose García
>> GeoCat bv
>> Veenderweg 13
>> 6721 WD Bennekom
>> The Netherlands
>> http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Pavel
I updated the wiki to add the cswservercapabilitiesinfo
Related to the path, I guess the page requires some additional changes to
point how to translate in 2.6.x and in 2.8.x
(xml/schemas/iso19139/present/metadata-iso19139-utils.xsl
is correct for 2.8.x while xsl/metadata-iso19139-utils.xsl is correct for
2.6.x
If you want to manage would be perfect. Otherwise, the best is to create a
issue to update this documentation.
Thanks and regards,
Jose García
On Tue, Jul 10, 2012 at 10:09 AM, Pavel Iacovlev
wrote:
> Hi Pavel
output.log
hopefully
> Regards,
> Jose García
>> > the languages list.
>> > wrote:
>> >> Hi Pavel
>> >> identify
>> >> the issue.
>> >> Regards,
>> >> Jose García
to
>> >>> output for : csw
>> >>> for :
>> >>> csw
version="1.0.0"
>> >>> </ows:Exception>
>> >>> for :
>> >>> csw
>> >>> for :
>> >>> csw
can
>> >>> >> Hello,
>> >>> >> metadata
>> >>> >> EN.
>> >>> >> make
RO.
>> >>> >> Steps I followed
FROM
>> >>> >> FROM
FROM
definitions
>> >>> >> to
>> >>> >> ro.
does
>> >>> >> not
>> >>> >> exist.
>> >>> >> Best Regards,
>> >>> >> Iacovlev Pavel
>> >>> Discussions
>> >>> malware
metadata
>> >> on
>> >> Jose García
>> >> GeoCat bv
>> >> Veenderweg 13
>> >> 6721 WD Bennekom
>> >> The Netherlands
>> >> http://GeoCat.net
on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
> http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
