[GeoNetwork-users] Adding background maps to viewer
I want to add "Bing Map Road" to background maps.
Bing Map Aerial is already defined so i copied and changed codes in these 3
files.
OwsContextService.js ( /opt/tomcat/webapps/geonetwork
/catalog/components/viewer/owscontext)
mapService.js ( /opt/tomcat/webapps/geonetwork
/catalog/components/common/map)
configViewer.xml ( /opt/tomcat/webapps/geonetwork
/WEB-INF/data/data/resources/map)
I deleted both of the server cache files and browser than restart the
tomcat.
I was able to see Bing Map Road on viewer but after refresing the page it
was disappeared.
Are there any other files to change ?
* How can i add my own maps?
Also, i couldn't be able to change center of the map from config.js What is
missing?
(/views/default/config.js )
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-background-maps-to-viewer-tp5299303.html
The context is saved on window closing.
So, i think you only make the OWSContextService to read your bing layer,
but maybe you forgot the writing part ?
On Fri, Dec 9, 2016 at 7:34 AM, hakanatak <hakanatak@anonymised.com> wrote:
files.
tomcat.
was disappeared.
missing?
Thank you
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today.http://sdm.link/xeonphi
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
Here is my OWSContextService.js file.I only added the bold code.
(290-322)
if (source instanceof ol.source.OSM) {
            name = '{type=osm}';
          } else if (source instanceof ol.source.MapQuest) {
            name = '{type=mapquest}';
          } else if (source instanceof ol.source.BingMaps) {
            name = '{type=bing_aerial}';
  * }else if (source instanceof ol.source.BingMaps) {
            name = '{type=bing_road}';*
          } else if (source instanceof ol.source.Stamen) {
            name = '{type=stamen,name=' + layer.getSource().get('type') +
          } else if (source instanceof ol.source.WMTS) {
            name = '{type=wmts,name=' + layer.get('name') + '}';
            params.server = [{
              onlineResource: [{
                href: layer.get('urlCap')
              service: 'urn:ogc:serviceType:WMS'
          } else if (source instanceof ol.source.ImageWMS) {
            var s = layer.getSource();
            name = s.getParams().LAYERS;
            params.server = [{
              onlineResource: [{
                href: s.getUrl()
          } else {
            return;
          params.name = name;
          resourceList.layer.push(params);
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-background-maps-to-viewer-tp5299303p5299318.html
Remove the first if statement ?
(290-322)
            params.server = [{
              onlineResource: [{
            params.server = [{
              onlineResource: [{
                href: s.getUrl()
          } else {
            return;
          params.name = name;
projects/geonetwork
*camptocamp*
*Florent Gravin*
0479444492
No, i didnt. I checked all codes son the file. This is the default file and
I only added the bold statement.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-background-maps-to-viewer-tp5299303p5299372.html
it nevers get into your else if statement as it goes in the previous one
projects/geonetwork
*camptocamp*
*Florent Gravin*
0479444492
