Hi everybody
I need add custom search field to geonetwork.
In this moment I configure on index-fields.xsl this code
<xsl:for-each
select="gmd:contact/gmd:CI_ResponsibleParty/gmd:individualName/gco:CharacterString">
<Field name="autormeta" string="{string(.)}" store="true"
index="true"/>
</xsl:for-each>
for search by metadata author.
How I do add this as custom search field on geonetwork?
Thanks....
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-Custom-Search-Fields-To-Geonetwork-tp5222995.html
Hi
You need to add in the search form a field with the name autormeta (the
same name as the lucene index field), so when the form is submitted the
value is used by the search service.
The form change depends on the GeoNetwork version you're using and in case
of 2.10, the UI (classic/extjs).
Jose García
On Mon, Sep 7, 2015 at 11:49 PM, cbeltran <cbeltran@anonymised.com> wrote:
Hi everybody
<xsl:for-each
store="true"
index="true"/>
</xsl:for-each>
Thanks....
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>M: +31 (0)655 818332 <+31655818332>
<https://www.facebook.com/geocatbv> <https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
Hi Jose,
Thanks for your reply.
The geonetwork version installed is 2.10.4 with Apache-Tomcat
It works with the config on index-fields.
I need integrate this variable as search field on Geonetwork.
For example:
<http://osgeo-org.1560.x6.nabble.com/file/n5223153/autorgeo2.png>
Thanks.
Regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-Custom-Search-Fields-To-Geonetwork-tp5222995p5223153.html
The UI is HTML5.
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-Custom-Search-Fields-To-Geonetwork-tp5222995p5223154.html
Hi
Check the code for generateAdvancedSearchForm in this file:
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web-client/src/main/resources/apps/html5ui/js/search/SearchApp.js
That code builds the advanced search form. You can use suggestions, like in
the organisation search field using a similar code for your new field:
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web-client/src/main/resources/apps/html5ui/js/search/SearchApp.js#L216-L237
You need to checkout the 2.10.4 branch from GitHub and build the web-client
with the changes to add the new field, so the files are minified.
On Tue, Sep 8, 2015 at 4:29 PM, cbeltran <cbeltran@anonymised.com> wrote:
Hi Jose,
For example:
Thanks.
Regards
