[GeoNetwork-users] Adding multiple languages to ISO19139 template: bug?
Hi there,
There appears to be a bug when adding more than one dataset language in the
ISO19139 vector template.
On clicking the '+' sign to add another language field, a 'metadata
language' field is added instead, and the latter only reverts to the dataset
language field after saving the record.
Richard.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-multiple-languages-to-ISO19139-template-bug-tp6045740p6045740.html
Hi Richard,
2011/2/20 RichC <richard@anonymised.com>:
Hi there,
this is related to http://trac.osgeo.org/geonetwork/ticket/122
The display is wrong, but the element reference is correct. For the
time being, the workaround is to trigger a refresh of the editor.
Cheers.
Francois
Richard.
The ultimate all-in-one performance toolkit: Intel(R) Parallel Studio XE:
Pinpoint memory and threading errors before they happen.
Find and fix more than 250 security defects in the development cycle.
Locate bottlenecks in serial and parallel code that limit performance.
http://p.sf.net/sfu/intel-dev2devfeb
GeoNetwork-users mailing list
