Hi Samin
Topic categories are part of iso19139 schema, so will only work with
metadata of that schema. Usually is not a problem, but in case you could
have metadata from different schemas you should be aware.
I would not recommend to use topic categories for this as the values are
defined in the iso19139 xsd:
https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/schema/gmd/identification.xsd#L287-L314
This means that you can add new values there, but if other catalogues
harvest your metadata, these news values will not be valid in case they use
the official iso19139 xsd to validate the metadata.
In any case if you want to extent this, you need to change previous list
and also the translations in the file (check for other languages if
required):
https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/loc/eng/codelists.xml#L1702
Jose García
On Mon, Jul 17, 2017 at 4:32 PM, Samin Payrosangari <s6sapayr@anonymised.com>
wrote:
Dear all,
I want to add some new options for topics to my geonetwork portal, so that
when someone wants to add new metadata he has more options for topic
categories to choose (of course this should be implemented in facets too).
Actually, there is a possibility to add newly defined categories (such as
"audio", "application", ...) in admin console --> classification
systems-->Category, but no such a setting for topics (such as "farming",
"biota", "inland waters", ...). Is it possible to do this? I have already
tried to add my own topic to gmxCodelists.xml but this seems not to be
enough.
Best,
Samin Payro,
Center for Development Research
University of Bonn
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
