Hi Guys
Note: in ISO 19115-3 there is a new way of managing overviews
The original way is still there but deprecated
Ideally use:
/mdb:MD_Metadata/mdb:identificationInfo/mri:MD_DataIdentification/mri:graphicOverview/mcc:MD_BrowseGraphic/~
mcc:fileName/gco:CharacterString <!-- this element is mandatory although cit:name below duplicates its use -->
<!-- this was always a clumsy way of providing the filePath -->
<!-- this element could be managed as null eg mcc:filename/ -->
mcc:linkage/cit:CI_OnlineResource/~
cit:linkage/gco:CharacterString <!-- this was claen way of providing the filePath -->
cit:name/gco:CharacterString <!-- Tidier way of dealing with the name (not filename) of the browse graphic -->
cit:description/gco:CharacterString <!-- Good way of dealing with the WCAG2 requirements for description of images -->
e
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@...1564...
-----Original Message-----
Sent: Monday, 24 September 2018 15:30
To: Andrew Rae <andrew.rae@...1463...>
Cc: Geonetwork-Users@...638...
Subject: Re: [GeoNetwork-users] adding overviews to iso19115-3 metadata
[Marketing Mail] [SEC=UNCLASSIFIED]Hi Andrew, could you open an issue with a metadata for testing in here
https://github.com/metadata101/iso19115-3Thanks.
Francois
Le lun. 24 sept. 2018 à 06:14, Andrew Rae <andrew.rae@...1463...> a écrit :
> Hi All
> I have been testing the iso19115-3 template using 3.4.3 with the
> iso19115-3 schema being compiled in.
> I have been having issues with adding overview images to new records.
> I go through the motions of trying to add a new resource.
> Setting the as Link dropdown as Overview for the rull resource or a
> subset
> I add the url for the image, the image appears and then I click the
> green Add online resource button.
> The window disappears and takes me back to the metadata record.
> With no overview resource being added. Saved the metadata record still
> no overview visible.
> Tried it by uploading an image and selecting it and also adding the
> url of an already hosted image on a webserver. No luck.
> Also monitored the log for any errors with nothing appearing in the log.
> I tried adding another resource like an ArcGIS lyr file without any
> issues and the tried adding a pdf file as well to see if there were
> issues for other resources. These links appeared fine within the
> metadata document.
> I also tried importing (although maybe or may not be a separate issue)
> when importing mef pr individual records originally being in
> iso-19139 they imported fine if imported as iso-19139 with the
> overviews being added as expected. When I tried to do a conversion
> from 19139 to
> 19115-3 I had the same issue with the overviews not appearing.
> Any help would be much appreciated.
> Thanks
> Andrew Rae
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at
> http://sourceforge.net/projects/geonetwork
>_______________________________________________
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
