Hi All
I have been testing the iso19115-3 template using 3.4.3 with the iso19115-3 schema being compiled in.
I have been having issues with adding overview images to new records. I go through the motions of trying to add a new resource.
Setting the as Link dropdown as Overview for the rull resource or a subset
I add the url for the image, the image appears and then I click the green Add online resource button.
The window disappears and takes me back to the metadata record.
With no overview resource being added. Saved the metadata record still no overview visible.
Tried it by uploading an image and selecting it and also adding the url of an already hosted image on a webserver. No luck.
Also monitored the log for any errors with nothing appearing in the log.
I tried adding another resource like an ArcGIS lyr file without any issues and the tried adding a pdf file as well to see if there were issues for other resources. These links appeared fine within the metadata document.
I also tried importing (although maybe or may not be a separate issue) when importing mef pr individual records originally being in iso-19139 they imported fine if imported as iso-19139 with the overviews being added as expected. When I tried to do a conversion from 19139 to 19115-3 I had the same issue with the overviews not appearing.
Any help would be much appreciated.
Thanks
Andrew Rae
Hi Andrew, could you open an issue with a metadata for testing in here
https://github.com/metadata101/iso19115-3
Thanks.
Francois
Le lun. 24 sept. 2018 à 06:14, Andrew Rae <andrew.rae@anonymised.com> a écrit :
Hi All
metadata document.
Thanks
Andrew Rae
GeoNetwork-users mailing list
